Rust? RUST!!!!
Old Feb 19, 2012 | 12:32 AM
printgoon's Avatar
printgoon
Rust? RUST!!!!
Looked at an FX4 F250 on the coast. Truck is located in a community right on the ocean. Good price then I started looking...7 years old the Rancho shocks have some rust on them, not the sliders but the paint and the affixing hardware. The shocks on a stock 250 really show so it caught my attention. Noticed the badges have lost most of their paint. You can see the muffler and CAT have rust on them...starting to look like the truck was parked in the water..lol But the engine bay is very clean no rust on the head studs, 1 owner, and the inside and the paint are without much of a mentionable blemish. The driver of the truck passed a few years ago and the car was rarely used for 2 years. What is too much rust? Its tough for me to judge, in cencal and about 7" of rain yearly I really don't notice any rust on any vehicles. Can any of you that regularly drive on salted roads and live in ocean side towns help me with a good guideline? Is a sign of surface rust pretty normal?
Last edited by printgoon; Feb 19, 2012 at 01:30 AM. Reason: gramericall, and spelin
Old Feb 24, 2012 | 07:09 AM
pbeering's Avatar
pbeering
Coastal air can be as big a challenge as deicing agents. Most of what you describe is cosmetic. Does the truck run ok? Is it tight? I would take it for a ride and put it in the air for an thorough inspection.
If you buy it, budget for fluids, filters, belts, shocks and tires
You might also consider having the bottom sprayed with undercoat
As for the shocks, replace with Bilstiens.
Old Feb 25, 2012 | 01:29 AM
printgoon's Avatar
printgoon
I would pay for an undercoat but how would I deactivate the rust? The truck, other that the noticeable rust' is very clean, and I bought it...unless something pops up was a very good deal.
Old Feb 25, 2012 | 09:03 AM
pbeering's Avatar
pbeering
A good shop will wash the underside with an acid solution and a detergent before applying the undercoat. Zeibart has such a system. Fluid Film on the rest.
See Fluid Film® | Corrosion Preventative, Lubricant and Rust Inhibitor
Mention FTE at familiar sounding online dealers
Old Feb 26, 2012 | 06:23 AM
TrdLtly's Avatar
TrdLtly
TreadLightly
My Father-in-Law tried Zeibart. Used them for years. In order for the warranty to be honored you have to take it in every Spring for service. He took it in one "week", not month, after the Spring service date one year. Nobody bothered to tell him he was late or that it would void his warranty. A couple years later with more services in between he had some rust he wanted warranted (Mid West winters). They pull up the computer screen and say "Sorry" we can NOT as he missed the cut off date several years ago. He even called corporate and they told him the same thing. I do NOT recommend Zeibart because of the way they DO NOT STAND BEHIND THEIR PRODUCT.
Old Oct 23, 2012 | 12:32 PM
northernredneck93's Avatar
northernredneck93
damn up here in ny its not suprising to see shocks completely rusted out. my chevy had most of the outside fenders of the box gone couldnt stand on the wheel wells because they were so close to falling out i wish i could find a used truck with that little rust
Old Nov 23, 2012 | 10:50 PM
crazyrwe's Avatar
crazyrwe
try some fluid film, spray or install right over the rust without removing.
Old Nov 24, 2012 | 08:31 AM
sammie0126's Avatar
sammie0126
I restored this one and you can see if the before photos it was so bad the front sway bar was rotted off the axle. But it took me about 2 straight weeks of angle grinding, degreasing, neutralizing and painting. Axle housing and sway bar were replaced. If the price is right anything can be fixed.
https://www.ford-trucks.com/forums/1...and-after.html
Old Nov 24, 2012 | 10:13 AM
crazyrwe's Avatar
crazyrwe
Yes, nice job Sammie, you have more energy than I do I think. I tried the lazy aerosol can way, hehe.
Old Jan 9, 2013 | 07:05 PM
mattb1990's Avatar
mattb1990
living near oceans wont be too bad, but driving on salted roads in snow will really mess your car up
Old Jun 6, 2013 | 11:57 AM
Pequeaford's Avatar
Pequeaford
PA is terrible with the salt. My 95 has holes over the back wells that I can put a finger completely through. Haha. O well duct tape will make it pass inspection.
Old Jul 18, 2013 | 12:44 PM
Ketchacar22's Avatar
Ketchacar22
If you are concerned about rust/corrosion of "body panels", here is a link to a Ford TSB for collision repairs. Undercoating does little, if anything to stop "panel rusting" or other components. Rust Inhibitor/Preventative is what is needed and suggest that you use only those which meet or exceed the ASTM-117B standard or the new SAE-J2334. I know of only three that meet or exceed both standards. Ford MotorCraft, MoPar or ValuGard products.
At ValuGard.net, under the Engineers Section are several Ford TSB's and "procedural instructions" you can inspect. Provides the MotorCraft part numbers, etc. Panel corrosion starts on the inside of the body panels, not the outside, by the way and undercoating does little to stop that from happening.
Old Apr 3, 2014 | 04:39 PM
Salts's Avatar
Salts
...im currently looking at using a rust converter and either using fluid film or oil spraying ( con with oil spraying is that out here on the sand you need to scrape it all off every once in a while), i don't really trust undercoatings i'm worried they can trap the rust if not done properly
fepowerguy8
General Automotive Discussion
Apr 29, 2010 02:38 PM
jdamato1
Appearance & Dress-Up
Feb 21, 2010 07:36 AM
gander801
Paint & Bodywork
Apr 18, 2007 06:16 PM
bobj49f2
23
Sep 26, 2006 05:15 PM
Encho
Paint & Bodywork
Jun 23, 2005 11:42 PM
