Valves not closing
Old Feb 18, 2012 | 10:46 PM
twk1956's Avatar
twk1956
Red face Valves not closing
I have an 88 4.9L missing on 2 cyls #s 1&3. No compression. Very log story short. When I backoff the non-ajustable rocker stud 1+ turn. Compression returns to 160.
Now what do I do? Was a valve job messed up.Appears to have just had one. I sure the answer is here abouts, I'm confused at this point.
Thanks twk1956
Old Feb 19, 2012 | 09:42 AM
Tote-M-Pole's Avatar
Tote-M-Pole
Check the length of your push rods. You could have two cylinders with odd ball push rods in the motor. Just for a check swap the push rods from the offending cylinders to different cylinders see if the issue followes to the other cylinders.
Old Feb 19, 2012 | 10:47 AM
JimsRebel's Avatar
JimsRebel
You should read this thread.
https://www.ford-trucks.com/forums/1...t-mystery.html
Jim
Alaska11
May 30, 2019 12:34 PM
406angler
Jul 23, 2017 08:38 PM
AbandonedBronco
Mar 20, 2011 02:58 PM
hellbilly1932
Feb 10, 2009 09:54 PM
trinogt
24
Aug 20, 2002 07:08 PM
