2002 7.3L stall issue
Old Feb 18, 2012 | 07:25 PM
The Tinman's Avatar
The Tinman
Question 2002 7.3L stall issue
I have a 2002 F250 7.3L 195,000 miles on it. It shuts down when under hood temp reaches normal max and wont restart until about 20 minute cool down. I am able to able to make this happen in the shop and the last shut down I replaced the CMP with a new one from ford still no start until cool down. There is no check engine light. Could it be the IPR ?
Old Feb 18, 2012 | 07:29 PM
F350-6's Avatar
F350-6
Welcome to FTE. Yes IPR is a possibility. Do you have a way to monitor ICP or IPR live data? Have you tried unplugging the ICP sensor to see if it still stalls when warm?
Old Feb 19, 2012 | 12:36 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
x2 on the ICP. Sounds like it works fine when cold since the PCM is following a map, but once warm it looks to follow a real signal and... .
How's the oil level? Dead IAT?
gasgofast
May 16, 2018 05:42 PM
Dahlfest
Mar 20, 2017 07:49 PM
Farmboypowerstroke
30
Dec 17, 2013 02:45 PM
gwolf58
16
Jun 11, 2010 05:23 PM
SprintRacer26
26
Mar 1, 2008 07:04 PM
