Sponsored by: Real Truck
Spring Problems
Old Feb 17, 2012 | 06:09 PM
Hayes Aluminum's Avatar
Hayes Aluminum
Spring Problems
I have a 2004 250 xcab with an 8' service body. I recently added a welder and the truck seems to lean to the side the welders on.. whats the best way to make this truck act like our larger trucks??? aftermarket springs or 350 or 450 springs...Metal Fabrication is my trade. NOT vehicle set up
Old Feb 17, 2012 | 06:14 PM
Hondaonda's Avatar
Hondaonda
F250 and F350 are the same truck with a different badge / GVW-CGVW and a 4"
rear spacer block vs a 2" rear spacer block on the F250.
Might try a set of more heavy duty leaf springs or better yet air bags so it can offset the one side only if you set them up independent of each other.
Old Feb 17, 2012 | 08:48 PM
F350-6's Avatar
F350-6
Overload springs will make a difference, but if you've got a service body and want to carry stuff around, I'd check into a set of air bags. That will allow you to level the load and support the weight.
CamperWill
Jul 3, 2018 06:01 PM
defekticon
May 24, 2016 06:53 AM
whodat_ford
2004 - 2008 F150
Feb 4, 2015 11:05 PM
94yj
Apr 4, 2008 06:46 PM
philips
May 26, 2005 10:06 PM
