Coolant Flush Machines
Old Feb 17, 2012 | 12:44 PM
DevilDocTater's Avatar
DevilDocTater
Master of Disaster
So whats the deal with the coolant flush machines. I know how they work, we had them at the oil change shop i worked at back in High School. My question is, can i fill up the machine with distilled water thus flushing all the old coolant out till you have clear clean water coming out. Next drain system, pour in one gallon of restore top off with distilled water drive around for 3 hours so the restore can work. Next hook flush machine back up, fill up machine with distilled water and flush till clean. Then flush in your new coolant.......will this theory work?
Thanks
Wade
Old Feb 17, 2012 | 07:51 PM
DevilDocTater
Master of Disaster
Any ideas?
Old Feb 17, 2012 | 08:14 PM
BLADE35's Avatar
BLADE35
I havent heard of anyone using a Coolant Flush Machine
The best way I found to clean the system is to remove the thermostat and do all the flushing and then add the cleaners Set to High Idel for at least an Hour while running the cleaners then flush till clear
It does get pretty hot sitting in driveway at high idel with the thermostat out
I did it with the thermostat in & driving around once shure didnt work as good as when I pulled thermostat out and set to High Idel for 1 1/2 hours
Old Feb 17, 2012 | 08:17 PM
DevilDocTater
Master of Disaster
sounds good, might try and tackle it tomrrow
jajones1988
Apr 22, 2014 11:51 AM
Boo_Daddy
Oct 29, 2013 07:53 PM
Poorboy04
Jul 22, 2012 06:47 PM
6litrefan
Feb 8, 2010 08:48 AM
DT 466Man
Nov 24, 2004 10:14 AM
