2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
How to install fog lights on 07 Navi
Old 02-16-2012, 08:06 PM
makajack's Avatar
makajack
makajack is offline
I recently bought an 07 Navi without the fog lights installed. I just purchased a pair of brand new oem fog lights and anticipated this should be a fairly easy job to accomplish. It came with brackets/on & off switch, bulbs, I mean the whole nine. I figured this can't be that difficult to install, after all the wires are visible from where the old one was previously installed and everything so I'm thinking this is a plug and play kind of thing. So I got up underneath the vehicle and could not figure it out. Again the fog light came with a bracket attached to it so I was expecting to see something under the truck for that bracket to screw on to but there was nothing. Am I missing something else that I need to purchase in order for the fog light to be mounted on? Please help!!!
Old 02-17-2012, 07:37 AM
TFWcustoms's Avatar
TFWcustoms
TFWcustoms is offline
I would remove the bumper, it would make things ALOT easier to deal with. When I painted the grille on mine i removed the bumper, its really not as daunting as it seems and you will have full access to the fog lights, they are a VERY tight fit, i remember fighting them to get them to pop out. Eventually they do and its fine.
Old 02-17-2012, 02:49 PM
berry1234's Avatar
berry1234
berry1234 is offline
It should just screw into the bumper. Can you take a pick of where the light goes?
Old 02-17-2012, 05:59 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
According to the factory manual it the backside of the bumper should look similar to the pic below.
Does yours have the lower grill piece (part #17B968 in diagram below) maybe it's required to mount fog lamps.
Matt
Old 02-17-2012, 09:10 PM
makajack's Avatar
makajack
makajack is offline
Matt,
After taking a look of your diagram, I think I am missing a piece. Part number 17B968, the lower piece is actually mounted into my bumper, but mines does not have the additional piece as in your diagram that has the four holes that accepts the four bolts. I'll have to visit Ford to get that. Thanks for showing me that diagram.
Pvincentt
2017+ Super Duty
48
01-23-2017 10:02 AM
RÖENTGEEP
02-24-2012 09:04 PM
Greyf100
08-14-2011 01:29 AM
2000f350v10
1999 to 2016 Super Duty
01-28-2010 06:41 PM
ScrewBuddy
2004 - 2008 F150
12-11-2007 10:07 PM
Quick Reply: How to install fog lights on 07 Navi
