6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
ESOF issue
Old 02-16-2012, 12:00 PM
Jock's Avatar
Jock
Jock is offline
ESOF issue
Have no four wheel drive unless I manually lock the hubs. Should the vacuum pump run continuously if I remove the outlet line. Mine doesn't but pump will run for a few seconds.
Old 02-16-2012, 07:08 PM
Jock's Avatar
Jock
Jock is offline
ESOF issue
Don't know if this will help anybody else but it turned out to be an easy fix. Vacuum pump would start if I tapped it so I removed cover & found a cold solder joint. Works fine now. Ford wanted $400.00 for a new pump.
Walleye Hunter
04-19-2014 10:54 AM
2000F250guy
15
02-05-2014 03:37 PM
greedy737
03-23-2008 08:44 PM
Medic 66
11-19-2006 04:17 PM
4X4 IN REFUGIO
09-29-2005 05:44 AM
Quick Reply: ESOF issue
