Fuel Pump
Old Apr 23, 2003 | 07:56 PM
deralaand's Avatar
deralaand
Fuel Pump
1994 F150 4x4 300 six 5 speed
Truck won't start, i installed plugs, wires, cap and rotor.
I have spark.
I suspect fuel pump...I hear the pump when I turn on the ignition but that doesn't mean it's pumping anything.?? I know I can check the fuel pressure at the small valve on the fuel rail. Can I check it with a tire gauge? or not?
If it is my fuel pump how dificult is the job? I'm assuming i'll need to drop the tank. This truck has two tanks.
How much fun am i gonna have and should i skip it and let the $85 an hour pro do it for me?
Any suggestions would be appreciated.
"D"
Old Apr 23, 2003 | 10:07 PM
steve83's Avatar
steve83
Fuel Pump
If you make more than $85/hr, let someone else do it. It's not that difficult - just tedious & time-consuming. It took me ~3hrs for my mother's Grand Marquis, but it's a lot harder to drop that tank and I was trying to take some shortcuts that didn't work. I think the last time I swapped my truck's tank, it only took ~2hrs.
I wouldn't put a tire gauge on that gas line for lots of reasons. A fuel pressure gauge is only ~$25 @ Sears.
Old Apr 24, 2003 | 01:32 AM
pfogle's Avatar
pfogle
Fuel Pump
you can get a high pressure fuel gauge at napa for around 15 bucks.
Old Apr 24, 2003 | 05:54 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
Fuel Pump
In your truck you have two pumps. Three if you have dual tanks. The one in the tank is the LOW PRESSURE pump. That feeds into the HIGH PRESSURE pump mounted on the left inner frame rail. The high pressure pump is the one you hear when you turn your key to the on position before you start your truck. It should run for a couple of seconds and then stop when it reaches its operating pressure. It sounds to me that your high pressure pump is good. Usually pumps either work or they don't. There isn't a in between. Check your fuel pressure. Should be around 45 psi (someone please correct me if I am wrong). Check your fuel filter to make sure it ain't clogged.
Old Apr 24, 2003 | 08:57 PM
steve83's Avatar
steve83
Fuel Pump
He only has one pump in each tank ('91-up); no pump on the frame rail ('84-90).
Old Apr 24, 2003 | 09:08 PM
jrs_big_ford_f150
Fuel Pump
Thanks for the info Steve, I didn't know that 91 and up only used one pump in the tank. I stand corrected.
Old Apr 25, 2003 | 01:09 AM
eckart's Avatar
eckart
Fuel Pump
If you hear the pump running odds are its pumping. Check your presure. Bad regulator or leaking rail and you wont have enough presure to fire your injectors.
Old Apr 25, 2003 | 09:10 PM
deralaand's Avatar
deralaand
Fuel Pump
Thanks to all who answered,
The crazy thing is the truck started tonight...but I don't want go anywhere with it because I know it won't start where I shut it off.
Any ideas why it would behave like this??
Could it be fuel filter? Or these regulators you guys were talking about. This problem makes it hard to get to work and even harder to pay for if I can't get to work.
Thank you,
"D"
