alternator voltage
Old Apr 20, 2012 | 09:29 PM
  #31
BLADE35's Avatar
BLADE35
Originally Posted by jkinghorn6.0
I'm over 450hp a per the torque app. In reverse it slips and it slips and then shifts real hard into 3rd and for some reason my trans fluid is burnt.
this from your other thread
Guess I might Lose a Buck here LOL
I thought it was just shifting Bad what is typical for injector issues
Burnt fluid and stuff is probably trans issue
Burnt fluid with slipping isnt good the FICM aint gona fix that
Old Apr 20, 2012 | 09:40 PM
  #32
jkinghorn6.0's Avatar
jkinghorn6.0
I got a p0203 injectors circuit #3
Contribution on
P0272, 0275, 0281, 0284.
P0620 generator contole circuit (if I remember corrrectly it has to do with the trans)
And nothing codes of p1000, p0098, and p0528. I only got the p0203 once about a month ago, the others were yesterday.
Old Apr 20, 2012 | 10:00 PM
  #33
BLADE35's Avatar
BLADE35
Contribution on
What Tunner are you running Bulley Dog or Edge or???????
Over 450HP you must be tuned the wrong tunner will KILL your tranny
<TABLE style="WIDTH: 681pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=908><COLGROUP><COL style="WIDTH: 77pt; mso-width-source: userset; mso-width-alt: 3730" width=102><COL style="WIDTH: 86pt; mso-width-source: userset; mso-width-alt: 4205" width=115><COL style="WIDTH: 237pt; mso-width-source: userset; mso-width-alt: 11556" width=316><COL style="WIDTH: 281pt; mso-width-source: userset; mso-width-alt: 13714" width=375><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black 0.5pt solid; BACKGROUND-COLOR: transparent; WIDTH: 77pt; HEIGHT: 12.75pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl66 height=17 width=102>P1000</TD><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 86pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl66 width=115>PCED</TD><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 237pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl65 width=316>OBD Systems Readiness Test Not Complete</TD><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 281pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl65 width=375>OBD monitors/drive cycle incomplete</TD></TR></TBODY></TABLE>
this from batterys unhooked no worries here^^
<TABLE style="WIDTH: 681pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=908><COLGROUP><COL style="WIDTH: 77pt; mso-width-source: userset; mso-width-alt: 3730" width=102><COL style="WIDTH: 86pt; mso-width-source: userset; mso-width-alt: 4205" width=115><COL style="WIDTH: 237pt; mso-width-source: userset; mso-width-alt: 11556" width=316><COL style="WIDTH: 281pt; mso-width-source: userset; mso-width-alt: 13714" width=375><TBODY><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black 0.5pt solid; BACKGROUND-COLOR: transparent; WIDTH: 77pt; HEIGHT: 25.5pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl66 height=34 width=102>P0528</TD><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 86pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl66 width=115>FSS</TD><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 237pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl65 width=316>Fan Speed Sensor Circuit No Signal</TD><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 281pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl65 width=375>Mechanical fault, short to voltage, open circuit, short to ground</TD></TR></TBODY></TABLE>
Need to check your Fan Clutch wire Harness right at fan shroud where it plugs together I can post pic if need be this can also cause a NO Start
<TABLE style="WIDTH: 681pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=908><COLGROUP><COL style="WIDTH: 77pt; mso-width-source: userset; mso-width-alt: 3730" width=102><COL style="WIDTH: 86pt; mso-width-source: userset; mso-width-alt: 4205" width=115><COL style="WIDTH: 237pt; mso-width-source: userset; mso-width-alt: 11556" width=316><COL style="WIDTH: 281pt; mso-width-source: userset; mso-width-alt: 13714" width=375><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black 0.5pt solid; BACKGROUND-COLOR: transparent; WIDTH: 77pt; HEIGHT: 12.75pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl66 height=17 width=102>P0098</TD><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 86pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl66 width=115>IAT2</TD><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 237pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl65 width=316>Intake Air Temperature Sensor 2 Circuit High Input</TD><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 281pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl65 width=375>Short to voltage, signal circuit open, IAT2 sensor</TD></TR></TBODY></TABLE>
Im not shure but the Fan clutch and IAT2 wires are in same harness it could be pinched or wire chaffe
P0203 Cylinder 3 Injector Circuit / Open G* g g D M J* E* e e D* U INJ-3 [DO]
<TABLE style="WIDTH: 681pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=908><COLGROUP><COL style="WIDTH: 77pt; mso-width-source: userset; mso-width-alt: 3730" width=102><COL style="WIDTH: 86pt; mso-width-source: userset; mso-width-alt: 4205" width=115><COL style="WIDTH: 237pt; mso-width-source: userset; mso-width-alt: 11556" width=316><COL style="WIDTH: 281pt; mso-width-source: userset; mso-width-alt: 13714" width=375><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black 0.5pt solid; BACKGROUND-COLOR: transparent; WIDTH: 77pt; HEIGHT: 12.75pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl66 height=17 width=102>P0620</TD><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 86pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl66 width=115>ALT</TD><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 237pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl65 width=316>Generator 1 Control Circuit</TD><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 281pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl65 width=375>Charging system</TD></TR></TBODY></TABLE>
need to make shure alternator/s are working right this could be why your FICM is BAD
Its very common for BAD Batterys or Alternator to KILL FICM
any issue with charging system will ruin FICM or other electronics
Im thinking the Injector contributation codes are from the BAD FICM
Old Apr 20, 2012 | 10:01 PM
  #34
jkinghorn6.0
What sucks is I had it rebuilt 2 years ago and I'm over the warranty. I just have too much power for the stock trans. I don't know what has been done to the truck before I got it but I know that before it started to run like crap It would break loose when I floored it at 35mph and could go from 60 to 100 in about 3 to 4 seconds. I'm not kidding. And I was getting 26mpg at 90 mph.
Old Apr 20, 2012 | 10:03 PM
  #35
BLADE35's Avatar
BLADE35
Right it has to be Tunned
what Tunner??? do you Know
I suspect tunner has taken out your Tranny
Old Apr 20, 2012 | 10:05 PM
  #36
jkinghorn6.0
I have the edge w/attitude.
Batteries are both new, about a year old. 900 cold cranking. What should I do, unplug the conector then plug it in again. I haven't seen any chafing I did just replace the rad
Old Apr 20, 2012 | 10:08 PM
  #37
jkinghorn6.0
I had all kinds of power before the tunner when I had the trans rebuilt the 1st time
Old Apr 20, 2012 | 10:12 PM
  #38
jkinghorn6.0
The truck won't be able to get out of its own way without the tunner.
Old Apr 20, 2012 | 10:14 PM
  #39
BLADE35's Avatar
BLADE35
Bulley Dog is the WORST tunner for the 6.0L trans
Edge is next in line as far as Hard/Bad for the 6.0L trans
SCT tunners are what folks here run and have Good succes with
I dont know to much about the diffrent tunners but if your EDGE is SOF type thats Very Hard on Trans
So you said it was rebuilt 2 years ago does that mean your Trans was rebuilt 2 years ago???
If so^^^^ you need to return the truck to stock see it that helps but sounds like the damage has already been done
If it were me I would Ditch the EDGE and get SCT
That Edge is Tearing your Trannys up IMO with this auto trans its very pickey about tunners you can about run any tunner you want with a standard trans just not an auto trans SCT tunner Only then you dont have to worrey
Sounds like this Tranny issue might be self inflicted damage
Old Apr 20, 2012 | 10:22 PM
  #40
BLADE35's Avatar
BLADE35
Thats weird
so will this be the 3rd trans rebuild??
I suspect you have other things going on here Especialy with the Grocery List of codes your getting
But get an SCT Tunner so the trans do keep going out
Did it lose power right after the EGR Deleate?? what deleate is it
Old Apr 20, 2012 | 10:25 PM
  #41
jkinghorn6.0
The trans was rebuilt 2 years ago. Well more like 2.5 years ago. Before the tunner. I was going to buy the ATS high performance trans and converter since I do tree work and haul a lot of wood and tow machinery. That's why I like the edge. A couple of my buds have banks and one has sct and they don't have the same power. I thought I would have gotten more time out of my trans.
Old Apr 20, 2012 | 10:34 PM
  #42
jkinghorn6.0
I don't know. I did the delete thinking that it was causing my hard start issue when it was hot but it wasn't the problem. I did it in the fall also the IPR, ICP, MAP, filters 3 times with Ford filters cleaned the intake to the best of my abilities w/o removal and acid bath cleaned the exhaust backpressue tube new injector harness
  #43
BLADE35's Avatar
BLADE35
Something is up since its eating trannys
Edge seems to be Hit n Mis some do ok and others eat there trans
Is it a SOF=Shift On the Fly Type tunner these type are Very Hard on it
Considering all the work thats been done A piched/chaffed wire harness maybe possible
Old Apr 20, 2012 | 10:35 PM
  #44
jkinghorn6.0
2nd trans since I bought the truck.
Old Apr 20, 2012 | 10:39 PM
  #45
jkinghorn6.0
Well if your in new jersey or Philadelphia you are more than welcome to come tinker. Lol.
