Engine compatibility?
Old Feb 15, 2012 | 04:02 PM
robnkim's Avatar
robnkim
I bought an '01 f350 auto with 7.3 liter turbo. Engine is bad.
I've found an engine in an '02 ambulance also 7.3 w/ turbo.
Any reason this wouldn't work as a straight swap?
Thanks
Old Feb 15, 2012 | 04:30 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
No problem with the switch. The only problem is if you have an auto in one and a manual shift in the other.
Old Feb 15, 2012 | 04:35 PM
CSIPSD's Avatar
CSIPSD
Thanks
Originally Posted by miller_feed
Welcome to FTE.
There is no problem at all... Just need to make sure you have the correct adapter on the back of the motor.
Only other thing is the 2002 will be out of a van, so you will have the van turbo and no IC piping... Just a matter of taking things off the bad motor and swaping it over.
Otherwise a weekend worth of work and your done.
Old Feb 15, 2012 | 04:38 PM
miller_feed
Joe, were all the ambulances Vans?
Old Feb 15, 2012 | 05:23 PM
bulla's Avatar
bulla
That's a good point Rick. Cause there not all vans. At least not around here! So robnkim, do you know if this ambulance is a van or superduty?
Old Feb 15, 2012 | 06:03 PM
robnkim's Avatar
robnkim
it's a 99. I was mistaken. I've looked at so many. Anyway, it's a super duty. He thought all that needed to be modified was something to do with the turbo, but his knowlege of the process didn't make me comfortable enough to travel that far and do all the work. So that's why I turn to you guys!
Does it being a '99 change anything?
Old Feb 15, 2012 | 06:08 PM
CSIPSD's Avatar
CSIPSD
Good point, there are alot of pickup ambulances...
Is it an early 99 or late?
Late 99- no issues at all other then what I mentioned above... And your getting Forged rods out of the deal...
Early 99- no major issues, just need to swap a few things to make it work right... Intake Plentums, Up pipes and all turbo parts and pieces, Injectors and the HPOP.
All these should come off your doner truck without issue assuming they are still good on it.
danyrock
Aug 24, 2023 09:55 AM
brandon_oma#692
WTB - Parts & other
Aug 30, 2017 11:26 AM
ca.viking
Apr 1, 2011 11:30 PM
That_Guy
Ford Truck Parts for Sale
Mar 16, 2011 09:42 PM
CanadianSmokie
Apr 23, 2010 06:53 AM
