6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
2008 6.4 no power
Old Feb 15, 2012 | 09:46 AM
swunderle's Avatar
swunderle
2008 6.4 no power
Wondering if anyone has solution. I have a 2008 F450 6.4. It is loosing power. No codes set no smoke. Rpm will not climb over 2500. Dealers is shooting in the dark. Problem is intermittent but has occurredatleast 5 times in 2 months.
Old Feb 15, 2012 | 01:59 PM
Schneiderboy07's Avatar
Schneiderboy07
Does the truck go into "limp" mode?
Old Feb 15, 2012 | 03:06 PM
Bender24's Avatar
Bender24
Any wrench or check engine lights? What are the codes that are stored? Fuel filters?
Old Feb 15, 2012 | 05:42 PM
senix's Avatar
senix
Get another dealer with a certified tech. Ask for a ride along with the flight data recorder.
Old Feb 15, 2012 | 09:08 PM
swunderle's Avatar
swunderle
No wrench. Don't know if it is in limp. Working on data logger now.
Old Feb 15, 2012 | 09:09 PM
swunderle's Avatar
swunderle
No codes. Just has no power.
Old Apr 16, 2013 | 07:58 AM
sroberts's Avatar
sroberts
runs good when weather is cool or raining. when warm outside looses power. can turn off key switch and restart. runs fine for 2 minand goes to no power again. engine light on. please help.
Old Apr 16, 2013 | 08:51 AM
senix's Avatar
senix
You will need to read the codes. You could try places like Autozone and see what it indicates. They can usually read the generic codes at least.
If you cannot tell then you will have to take it into Ford and have it read.
Are you still under warranty?
Old Apr 16, 2013 | 11:37 AM
parkland's Avatar
parkland
I am thinking since you have no check engine light, or wrench light or whatever, it can't be in limp mode, but I could be wrong. But I'm pretty sure that if the engine reduces power, there would be a light or notification.
Are you tuned?
Mason Guettner
Sep 14, 2017 09:30 AM
Corey Zion
Modular V8 (4.6L, 5.4L)
Dec 13, 2016 06:54 PM
suds
Apr 11, 2013 10:33 PM
KAGC
Feb 17, 2012 07:49 AM
6CylBill
26
Jul 21, 2010 03:23 PM
