Engine Won't Shut Off?
Old Feb 14, 2012 | 09:11 PM
Tejaswolf's Avatar
Tejaswolf
My boyfriend recently purchased a 1966 F100 Twin I Beam;
It drove just fine for a couple of days, then what we thought at the time was the starter going out fixed the problem. Once we replaced it, drove just fine until it tried to go a long distance, it would die if he stopped too long and he'd have to gun it pretty hard to keep it going.
When he got home and went to turn the car off after the long trip, he took the keys out totally and the engine was still running. Unhooked the battery--engine still running. We had to disconnect the start solenoid to get it to shut off. We thought maybe it was bad, so we replaced it. And it wouldn't crank. Well--we checked the starter and it had burned up; we put the old one back in because it would still turn over. Truck cranks but when we crank it, it still keeps trying to turn over, the ignition will not disengage. We tried replacing the ignition switch, still no go.
Any ideas on what it could be?
I'm guessing it's a wiring issue--
He's really hoping otherwise.
Any ideas will be greatly appreciated.
Old Feb 14, 2012 | 09:39 PM
Elvis40's Avatar
Elvis40
Sounds like you could have a mixture of problems. These vehicles do not need the battery to run if the alternator is charging.
It sounds like you have a short somewhere. By ignition switch did you actually pull the ignition assembly out of the dash to make sure the wires are not shorted out?
Did the starter by chance short out and stick to the flywheel causing it to burn up?
If it's a stock v-8 it is a 352FE and inline i believe would be the 300.
Old Feb 14, 2012 | 09:56 PM
Tejaswolf's Avatar
Tejaswolf
We pulled the whole ignition out, checked all the wires--and the fly wheel is brand new, we checked it when we changed the starters back out. I'm thinking it's a short too. Just narrowing it down is the hard part. He could re-wire it, he's just in the Army and Thursday leaves back for Afghanistan.
Old Feb 14, 2012 | 10:31 PM
70-360fe's Avatar
70-360fe
This is for a 67 but should close or the same.
http://www.fordification.com/tech/wi...ing-gauges.jpg
Ok may be a long shot but could the voltage reg. be bad and cause the relay to malfuncation?
Old Feb 14, 2012 | 10:44 PM
Tejaswolf's Avatar
Tejaswolf
I'll let him know about that one tomorrow when he comes over. Truck is parked in front of my house right now lol. Any ideas are awesome right now. So thanks for the ideas everyone and help. (:
Old Nov 25, 2014 | 07:59 PM
69issofine's Avatar
69issofine
next time it won't shut off grab the coil wire and give it a pull it will shock the obama out of you but the engine will die.
Old Nov 28, 2014 | 05:12 PM
Red69's Avatar
Red69
I had this problem. The starter would drag when the engine was warm. The truck would not shut off sometimes when you turn off the switch and I would have to pull the wire off the "I" terminal on the solenoid to kill the engine.
The problem ended up being a bad diode in the alternator. It would back feed the ignition circuit through the solenoid. After the alternator was rebuilt the starter worked fine even warm and the truck always shuts off with the key.
Old Nov 29, 2014 | 03:30 AM
jowilker's Avatar
jowilker
You guys are responding to a two year old post. Hopefully the guy has completed his tour and is enjoying his truck.
John
Tonto Kowalski
Feb 2, 2022 08:06 PM
LRSTony
1997 - 2003 F150
Jun 11, 2015 03:40 PM
kimak1970
Jul 11, 2013 11:24 AM
trucking79
Nov 24, 2004 02:56 PM
thelakecrew
Bronco II
Jan 10, 2002 09:21 PM
