Excursion 6.0 sputtering
Old Feb 14, 2012 | 07:47 PM
Duksrule's Avatar
Duksrule
I have an 03 Excursion with a 6.0. It is a 4X4 with 152K miles on it. Sometimes while driving it sputters. Almost like it was a gas motor missing. It will drop 2-300 RPMs and then picks up and runs fine. The only thing that has ever been a problem on this truck is that I had to have a few injectors replaced and a new fuel pump put on at the dealer. That was 2 years ago and the truck ran great till the new problem. It started back in December and I took it in to the dealer thinking it was injectors again. They said there wasn't anything wrong accept that it needed an update to the Fuel Injection Control Module. After that it ran fine until about a week ago. I have changed the oil, both fuel filters and have run many tanks of fuel through it. It doesn't throw any service engine lights. And only does this for a second or so and then runs fine. There is obviously something wrong with it but I don't want to take it back to the dealer if they aren't going to find anything.
Also I have an air raid filter on it and when it misses it sounds like air is coming back up through the air filter.
Any ideas?
Thanks
Old Feb 14, 2012 | 08:02 PM
BLADE35's Avatar
BLADE35
Air coming back threw the air box is called a Turbo Fart
It sounds Like you might be having some turbo issues
It could be a sensor that controls turbo operation or might just need to Clean the turbo
Due to the after market Air filter setup you might have Dusted the turbo sounds like it needs to come out for a Cleaning
OEM air filter setup is the Best if you still have the OEM air filter setup I would throw it Back ON
Do you Have any gauges???
Need to monitor MAP,BARO (and maybe EBP but being an 03 EBP maynot be figured into the Calibration IDK worth a Try IMO) at KOEO need to be within 0.5 psi of each other
Old Feb 14, 2012 | 08:17 PM
Duksrule's Avatar
Duksrule
Would a bad sensor not trip a code or show up on the dealers scanner? I have a Boost and EGT gauge. I will try to look and see if it is loosing boost when it happens.
Any way to test the sensor? I took the turbo out and cleaned it a few years ago. It doesn't do this all the time and it ran perfect for two months after the dealer updated the FICM. Is there a way to test anything or is splitting the turbo the only option?
Can you give me some more details on the KOEO test? I will see if my scanner can check that stuff.
Old Feb 14, 2012 | 08:47 PM
jfirstford's Avatar
jfirstford
Sounds like the problem I had a few years back:
It was a coked up turbo that turned out to be the problem for me. Getting your turbo cleaned might do the trick, you may have a unison ring sticking or something like that.
Old Feb 14, 2012 | 08:50 PM
BLADE35's Avatar
BLADE35
Originally Posted by Duksrule
Would a bad sensor not trip a code or show up on the dealers scanner?.
If it had a code at the time it was in the dealer yes they would have seen it
Sometimes the PCM wont Light the CEL imediatly it may take a few drive cycles with a bad sensor/reading for the PCM to Light the CEL
just depends if its something thats continuously monitored
I have a Boost and EGT gauge. I will try to look and see if it is loosing boost when it happens. .
With air blowing back threw the Air Box (turbo Fart) you have an Over Boost condition NOT under boost
Any way to test the sensor? I took the turbo out and cleaned it a few years ago. It doesn't do this all the time and it ran perfect for two months after the dealer updated the FICM. Is there a way to test anything or is splitting the turbo the only option?.
You can test any sensor
All sensors use a Volt reading to transfer the Sensor Value from the sensor to PCM
If the Value is out then it sets a CEL
Also you can have a DTC (Diagnostic Trouble Code)without a CEL
KOEO = Key On Engine Off
I use a ScanGauge II to look at the MAP,BARO,(and EBP on some models) these are some of the sensors used in determining Boost output because there Pressure Sensors
A scan gauge makes reading these sensors easy
But I suppose you could use a DVM if you knew what Voltage = what PSI
Old Feb 14, 2012 | 08:55 PM
BLADE35's Avatar
BLADE35
BTW it would be best to fix it soon because OverBoost could lift the Heads off the Deck
And Might want to look into a SGII it would show you alot of diffrent sensors Values
160.00 for SGII either from an autozone or here www.scangauge.com
supperman2k
Aug 9, 2011 12:41 AM
hifiman
Sep 8, 2010 07:44 PM
Bender99
Jul 27, 2010 02:30 PM
jlong05
May 5, 2010 04:37 PM
Finally
Sep 26, 2004 01:58 PM
