Need Parts help
Old Feb 13, 2012 | 11:12 PM
ffflash480's Avatar
ffflash480
Need Parts help
I need a 61-66 metal instrument panel with the big round speedo in it. I am in North Dakota and parts are slim to none. Any help locating one or if someone has one they would sell please let me know. I did check the for sale stuff and found nothing. Thanks....
Old Feb 14, 2012 | 06:48 AM
huckdeuceman's Avatar
huckdeuceman
Check ''Ebay'' I saw one just the other day on thier! just click on Ebay and type 65/66 ford pickups and it will list all pickups and parts...,or I'm sure someone will chime in here that has one you could get!...good luck.
Old Feb 14, 2012 | 08:05 AM
Broomfieldbum's Avatar
Broomfieldbum
If you need the just the speedo, I have one. I would send it to you for the shipping. I upgraded mine to one out of a newer Bronco, so I could have Amp and Oil Gauges without changing the stock look. If you want it, send me a PM and we can make arrangements for the exchange. I do not have a spare metal Bezel.
Old Feb 14, 2012 | 10:17 AM
Mikulh's Avatar
Mikulh
If you just need the bezel without the speedometer & gauges I have one that I would sell. PM me if interested.
Old Feb 14, 2012 | 10:34 AM
Customcab's Avatar
Customcab
I'm always curious at seeing different styles; Do you got a pic of this upgrade?
Old Feb 14, 2012 | 11:03 AM
Broomfieldbum
This is like the one I put in. I would take a shot of mine, but my truck is in the shop getting new floors welded in.
Old Feb 14, 2012 | 11:04 AM
Broomfieldbum
Whoops missed the Picture
Old Feb 15, 2012 | 09:20 AM
Mikulh's Avatar
Mikulh
I like that. Did you have to make any wiring changes to use the oil pressure and alternator gauges?
Old Feb 15, 2012 | 09:43 AM
garbz2's Avatar
garbz2
The amp guage works off induction. The primary wire goes through a loop.
For the Oil you need to change the sending unit to a guage type as the stock one is just a switch and reuse the stock white with red stripe oil pressure wire with an add on to the guage regulator.
66 to 77 broncos use these and you will find them in the larger trucks to 66 and in T and N series untill 72
Dakota Digital makes a direct fit electronic unit.
This is about the baddest assed guage set ever!
1966- 77 Ford Bronco VHX Instruments
And the other one.
1966 - 1977 Ford Bronco Digital Instrument System
Garbz
Old Feb 15, 2012 | 12:24 PM
camperspecial65's Avatar
camperspecial65
I have a few of these...one with holes for the gauges and a couple w/o the gauges...one with holes is chrome...
I too have a speedo head and anything else you need for this type of cluster setup.
- cs65
chriscris
Aug 6, 2016 08:53 AM
F250racer
Dec 15, 2013 10:10 AM
gangstakr
Aug 23, 2009 11:20 PM
john fin
Nov 21, 2008 10:23 AM
drof46
Apr 15, 2006 10:17 AM
