Dana 50 Locking Hubs
Old Feb 13, 2012 | 07:16 PM
lonewolf016's Avatar
lonewolf016
Got a truck a month ago. PO had lost a wheel bearing and it took the hub with it. He made a make shift patch to cover the hole and ran the truck in 2wd for 10 years. Well I got the truck and needed 4wd, so I bought a set of Warn hubs. Driver side went in without a problem. The passenger side not so much(Its the side that lost the wheel bearing and lock out). The shaft won't go completely through the locking hub to put the snap ring on the shaft.
Seeing that the end of the shaft was at an angle or beveled a bit. I thought maybe it didn't really need the snap ring. The shaft doesn't come out of the hub. But when I lock it in it makes some rattling sounds. Doesn't do it when I'm on the gas, but does when I'm coming to a stop or hit a bump.
So, my question. Does that axle shaft have to have the snap ring? It's about 1/2 inch to short. What can be going on?
Old Feb 14, 2012 | 06:40 AM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE.
i wonder if the idiot ground the end of the axle stub down to fit the cover plate on it?
Old Feb 14, 2012 | 07:45 AM
White Max's Avatar
White Max
Agreed. Post up a pic so we can see what is going on. Another possibility is that the shaft isn't pushed all the way out when you're trying to put the snap ring on. Grab the u-joint and push the shaft outwards to make sure it's fully engaged in the hub.
*That's as best as I can explain it this early in the morning.*
Old Feb 14, 2012 | 07:55 AM
kd0axs's Avatar
kd0axs
This could be the problem. Reach back behind the knuckle where the U-joint is and pull out on the axle shaft. It might slide out enough to get the snap ring on.
PSDlongbox
Nov 30, 2013 04:08 PM
westandr
Aug 16, 2011 07:38 PM
junkrider
Nov 7, 2009 11:29 AM
Built_Ford_Tough_757
Jul 8, 2009 11:24 AM
ford&excavators
Jul 27, 2008 10:41 PM
