1978 - 1996 Big Bronco
EGR and Heater problems
Old Feb 13, 2012 | 07:01 PM
mater73's Avatar
mater73
Well after my issues with getting the water pumb replaced i moved on to trying to figure out why my heater wasnt blowing hot. tonight i took it up to a friends shop and we hooked a smoke machine to the vacume lines and discover that the heater control valve is bad. also while having it hooked up to the smoker we say that there was smoke coming out of the EGR valve. so both of those parts are getting replaced tomorrow. so i hope that by time i go to bed tomorrow i have a heater that heats. because it is really cold without it.
Old Feb 13, 2012 | 07:48 PM
Pat Kolb's Avatar
Pat Kolb
A smoke machine? that sounds like a cool tool. would have saved me hours checking them with my vacuum pump
Old Feb 13, 2012 | 08:13 PM
mater73's Avatar
mater73
Yeah its bad *** works great if you have a vacume leak or a bad egr like I do it will find it. I know for a fact you can get one through snap on tools but not sure on cost.
Old Feb 13, 2012 | 08:33 PM
greystreak92's Avatar
greystreak92
The smoke/haze machine to test air flow and vacuum is common practice for me but then they are common equipment in my line of work so easy to come by. But then I use high-intensity stage-lighting fixtures to heat thermally reactive sensors without running the engine too.
Old Feb 13, 2012 | 08:46 PM
mater73's Avatar
mater73
The lighting fixtures sound cool
Old Feb 13, 2012 | 11:21 PM
critterf1's Avatar
critterf1
The EGR valve is naturally going to smoke when smoke is introduced, doesn't necessarily mean that it's defective.
treeves68
Nov 16, 2018 08:39 PM
12amracer
Jul 29, 2013 01:40 PM
dillman
Jan 7, 2013 07:19 AM
Razor Back Bowhunter
Dec 21, 2012 08:53 PM
brentleedragon
Oct 8, 2006 11:38 AM
