55 239 Y-Block Restoration Thread
#1186
Yeah, this summer I will probably leave it out more so I have more excuses to drive it.
Here is my saga of dropping a tie rod while driving: https://www.ford-trucks.com/forums/1...-fall-off.html
Today my mud flaps arrived. They are 18.5" wide. I figured I would need to cut them down, but since I will attach them a ways back from the tire, I think they will look just fine. I'm not sure when I will get a chance to install them.
I need to temporarily attach them to see what they look like standing behind the truck.
#1188
I was thinking about weathering them with the Vinegar/Steel Wool solution, but I'm not sure I want to do that. I was thinking if I completed body work and paint, the weathered looks wouldn't go over too well.
If I painted, I don't know what color I would use. Sea Sprite Green will take extra effort to find.
I do like the wood grain look, so I will probably stain them.
I've never been known for my upper body strength. Maybe I should drive my truck more often to get more exercise.
Also, It is supposed to rain today so I went ahead and put the truck back in the garage. I was able to do it without letting air out of the tires. It rubbed a little on the rubber seal on the top of the garage. That was nice. I just need a couple hundred pounds in the bed and it should go in and out easy.
#1189
Thanks Steve, I have to balance the patina of the truck with the nice new bed.
Between all the tie rod stuff and being sick, as well as my daughter, I clamped the mud flaps onto my truck in about the location I plan on putting them.
I don't think I will need to cut them down any. I need to drill some holes in the bed crossmember of the bed and bolt them up.
#1191
#1193
Thanks for the well wishes guys. Getting better, really not too bad, but it sure is annoying having to cough whenever you talk much. I have a business trip Sunday and tons of stuff to get done at work before I go.
Excellent suggestion. I was thinking about how to get these off easier. Handles on the back end will really help.
A side not on sideboards. I put the stakes in the holes then attached the sideboards. I quickly discovered that if your stakes aren't in straight, It is very difficult to get them back out. So, when I finally got them out, I fixed them so they would all go in the stake pockets smoothly.
#1196
Small update. I have a gal at work that does vinyl stuff, so I had her make me a ford script in outdoor vinyl.
Before:
After:
She accidentally made one in reflective white vinyl and a little too large. I have that one and a smaller one as well. Just have to figure out what to do with them. I'm very pleased!
Next step, mud flaps. Gotta get them installed.
Before:
After:
#1198
Unfortunately I haven't had an opportunity to get my truck out. My mom in in ICU in Springfield after her lungs filled with blood during a heart valve replacement. We are 10 days in and hoping to begin weaning her off the vent. So, Gwen and I have been spending a lot of time down there.
I'm pondering removing my caster shims to see what that does, but I need to drive it for a while to see how it is driving first.
#1200
