Block heater
Old Feb 13, 2012 | 08:24 AM
mudguts's Avatar
mudguts
Block heater
Hi : I'm looking at putting a 1000 W block heater in instead of my 600W I was wondering would a 1000W be safe to run? Thank You Mudguts.
Old Feb 13, 2012 | 08:50 AM
Jayme Duty's Avatar
Jayme Duty
that is what i run. Works great. I am working in ND and have temps -25 and starts first crank
Old Feb 13, 2012 | 09:56 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Depends on what block ... the older 6.9 block should not have a block heater at all!
-Enjoy
fh : )_~
Old Feb 13, 2012 | 07:25 PM
mudguts's Avatar
mudguts
My block is a 1985, I'm in the process of a rebuild and just replacing everything. it's close to going in, now just Torqued the heads yesterday.
Old Feb 14, 2012 | 09:28 AM
Festus Hagen
Methanoholic
You are rebuilding a 85 block and you don't know if it's the older casting or newer casting ... Brave!
Here is a post by Dave Sponaugle that gives the needed info: 6.9L Block ID
-Enjoy
fh : )_~
Old Feb 14, 2012 | 10:06 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
if you find you have the older block and you need/want a heater.then just get yourself an inline coolant hose heater.
Old Feb 15, 2012 | 05:16 AM
mudguts's Avatar
mudguts
well it came with a block heater, from the factory, talks about it in the owners manual, so that tells me it's a newer casting,
Old Feb 15, 2012 | 08:57 AM
FORDF250HDXLT
i think they all did since '83 there mudguts.
those who knew about the issue and were wise,cut their heater cord plugs.
its my understanding that many didn't find out about the issue until it was too late back in the day,know what i mean?
for years now,its been known to cut the cord right off so no one can mistakenly plug them old blocks in.
Old Feb 15, 2012 | 12:18 PM
Festus Hagen
Methanoholic
An ASSUMPTION like that could cost you a motor!
-Enjoy
fh : )_~
Old Feb 15, 2012 | 01:17 PM
artfd's Avatar
artfd
Exclamation
I've been using my block heater since 1983, in cold weather. Haven't killed the engine yet.
Old Feb 15, 2012 | 06:13 PM
mudguts's Avatar
mudguts
OK so what #s on the block do I look at, to determine wether it is an early cast or the later cast? Thanks MudGuts
Old Feb 15, 2012 | 06:16 PM
Festus Hagen
Methanoholic
In Post #5 I included a link to the info for the 6.9 block ID.
-Enjoy
fh : )_~
Old Feb 16, 2012 | 06:47 AM
mudguts's Avatar
mudguts
Thanks, I will check it out.
Old Feb 16, 2012 | 04:21 PM
rhkcommander959's Avatar
rhkcommander959
Found out a while ago that my engine was a junkyard swap early cast.
I could tell by the junkyard chaulk on the valve covers and the crushed oil pan where he must've tried to jack it up...
Dropped the starter because it was leaking coolant from where I thought the block heater was. Pulled the starter and saw some weird coating of some waxy junk. Ripped it out, was about half an inch thick at least and was covering a 4" welded section that was leaking coolant. No block heater
Ran some sort of block-based stop leak stuff and it's slowed the leaking down by far. Still sucks. I would rebuild this block if it wasn't for the mound of welds, but I've got another one from 87 that will be getting cleaned up probably
Old Feb 16, 2012 | 07:25 PM
mudguts's Avatar
mudguts
Smile
This block I have I just got back from the machine shop, where they hot tanked it, bored it 20 over,magna fluxed it and pressure tested it. they said it was good to go. but I will check the #s any way,and if it blows. Then I know where I can get a 1988 or 89 7.3 that starts right up, I personaly like working on these engines, It's relaxing compared to pouring concrete in the Arizona sun.lol MudGuts
mblayton
Ford Truck Parts for Sale
Jan 9, 2017 05:53 PM
knash0727
17
Dec 4, 2009 10:26 AM
QUINCE
Nov 6, 2008 10:40 AM
CrazyMax
Escape & Escape Hybrid
Jan 18, 2007 01:24 PM
sprocketford
Dec 15, 2004 10:36 AM
