f100 cummins
Old Feb 12, 2012 | 09:01 PM
fordguy2236's Avatar
fordguy2236
f100 cummins
me and my dad are going to be doing an f100 hopefully soon and we are wanting to drop a cummins 12 valve 5.9L into it. does anyone know how much fabrication this would take or if its even possible. my dad has pretty good fabrication skills and im learning so nothing is really out of question
Old Feb 12, 2012 | 09:31 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
Cummins 4BT & Diesel Conversions Forums
this is some good reading and should keep you busy!
Old Feb 12, 2012 | 10:38 PM
mtflat's Avatar
mtflat
I don't think I'd do it in a half ton - the weight is about double for any other engine you might have had.
Old Feb 12, 2012 | 10:39 PM
HT32BSX115's Avatar
HT32BSX115
You might consider finding an F250 or F350. The suspension and frame in an F-100 is a little light for the roughly 1000lb 6BT.
It is very common for people to put the Cummins 4BT in 1/2T pickups though...
Old Feb 13, 2012 | 08:06 AM
fordguy2236
What would I have to beef up to make it work in a 1/2ton? I might be abl to find an f1 they are harder to find though they are 3/4 tons arnt they
Old Feb 13, 2012 | 08:33 AM
carbs & chrome's Avatar
carbs & chrome
F1 is a 48 - 52 1/2 ton.
Should be just as easy to find a 3/4 ton + as a 1/2 ton.
Old Feb 13, 2012 | 09:10 AM
fordguy2236
Is there f100 3/4 tons
Old Feb 13, 2012 | 09:16 AM
carbs & chrome
48 - 52 = F2
53 - 56 = f250
Old Feb 13, 2012 | 09:27 AM
fordguy2236
I thought that 53 was still an f100
Old Feb 13, 2012 | 09:35 AM
carbs & chrome
f# = 1948 - 1952
f### = 1953 - 1956
f1 / f100 = 1/2 ton
f2 / f250 = 3/4 tom
f3 / f350 = 1 ton
Old Feb 13, 2012 | 09:43 AM
fordguy2236
Ok thx ill look for an f2 or f3 then
Old Feb 13, 2012 | 10:31 AM
GB SISSON's Avatar
GB SISSON
They aren't as easy to find, but they are a good engine and about 300 lbs less then the 6bt. The 6at was originally used on onan gensets, but an automotive version was brought out in the late 80's. Lots of UPS trucks were repowered with them. I'm running one in my 3/4 ton gmc, and I bought another off cl that I hope to put in my f350 fridge. Almost same dimensions as the 223 six that's in there. 220 cu in and 120 hp, but I've read that they can be made to produce a lot more if they are tweaked. I've seen some youtube videos of them in various trucks, even jeeps and landcruisers. Very simple swap really and there's no doubt it's a cummins under the hood.
Old Feb 13, 2012 | 01:00 PM
mtflat's Avatar
mtflat
Originally Posted by carbs & chrome
f# = 1948 - 1952
f### = 1953 - 1956
f1 / f100 = 1/2 ton
f2 / f250 = 3/4 tom
f3 / f350 = 1 ton
Almost correct.... for '52 it is...
but in 1948-50 and perhaps even 51
F1 was the 1/2 ton: gvwr 4700
F2 was Light Duty 3/4 ton: gvwr 5700
F3 was a Heavy Duty 3/4 ton: gvwr 6800
F4 was a 1 ton: gvwr 10,000 for one variant
F5 was 1 1/2 ton
F6 was 2 ton
F7 was 2 1/2 ton
F8 was 3 ton
From F4 on there were multiple gvwr's depending on tire size and if dual rear wheels.
The ratings don't really mean much in the real world AND they were different for Canada
Old Feb 13, 2012 | 09:06 PM
fordguy2236
does anyone on here live in the omaha nebraska/council bluffs iowa area? if so do you know of any f2 or f3 for sale. i would like a 50-55
Old Feb 13, 2012 | 10:20 PM
HT32BSX115's Avatar
HT32BSX115
Well,
If it were me,
I like this one!!! 1954 Ford F-600
More,
1956 Ford Pickup
1956 ford f350 1ton
you might have to drive around and look. There's a lot of them out there in radio land.....
