IC is installed
Old Feb 13, 2012 | 03:00 PM
  #31
strokin'_tatsch's Avatar
strokin'_tatsch
Originally Posted by MHammer21
Hairspray??? please elaborate. Inquiring minds want to know
If you put a little bit of hair spray on the boot when you install it, it will help the boot stick to the IC pipe and make it a little harder to blow off.
Old Feb 13, 2012 | 03:02 PM
  #32
fordpride's Avatar
fordpride
Spray the inside of the boots with the cheapest hair spray you can find to help the boots stick to the pipes
Old Feb 13, 2012 | 03:24 PM
  #33
MHammer21's Avatar
MHammer21
Nice, thanks for the info. Is this common practice for the Turbo boots as well?
Old Feb 13, 2012 | 03:29 PM
  #34
fordpride's Avatar
fordpride
No the y pipe is held down by the turbo
Old Feb 13, 2012 | 09:05 PM
  #35
Leemakesmepee's Avatar
Leemakesmepee
Is there a big diffrence between alum and steel pipes? like is there more airflow with one or the other?
Old Feb 13, 2012 | 09:07 PM
  #36
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Congrats Mike for the install and the good deal you got there (free), I want to see the pics after paint.
BTW if the boots continue blowing off, you need like a ring wire welded at the end of each pipe.
Old Feb 14, 2012 | 12:11 AM
  #37
oldbird1965's Avatar
oldbird1965
That's exactly what I did!
Looks great Mike, your making improvements at the speed of light!!
(cough, cough, clear my throat, George, got that T500 in?)
Old Feb 14, 2012 | 07:28 AM
  #38
fordpride's Avatar
fordpride
Glenn I still have e fuel to be put it.
Old Feb 14, 2012 | 09:49 AM
  #39
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
I dont think that are any diff between them in airflow, just the strenght, appareance and the diff type of welding IMHO.
Old Feb 14, 2012 | 01:24 PM
  #40
Fullcrew7.3's Avatar
Fullcrew7.3
Actually, the hairspray that was mentioned is merely to help the guy working on the truck in his attempt to look like he knows what he's doing. Nice hair= nice truck, right?
Old Feb 14, 2012 | 01:41 PM
  #41
fordpride's Avatar
fordpride
That's rite if you don't know what your doing and all else fails atleast look good while your doing it
Old Feb 17, 2012 | 03:35 PM
  #42
fordpride's Avatar
fordpride
Finally got some good clamps. Before the IC at 70-75 EGT's would sit around 700 now I'm at 550-600. All this is in my 100hp setting.
Old Feb 17, 2012 | 03:37 PM
  #43
chicagodragon's Avatar
chicagodragon
Did you get my intercooler? I need good news right now
Old Feb 17, 2012 | 08:13 PM
  #44
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Glad to know, now you have to do some towing test. and change your signature
Old Feb 17, 2012 | 10:04 PM
  #45
fordpride's Avatar
fordpride
Jose hopefully I'll have a towing test for it in a couple about 7000 lbs. of sod(grass). Sig is fixed
George I wasn't able to get it today
