IC is installed
Old Feb 12, 2012 | 06:11 PM
427 fordman's Avatar
427 fordman
Alex, fyi my trucool is behind my IC, and I've never seen over 200. That was in a 95* windy day with the trailer on. That's plenty cool.
Old Feb 12, 2012 | 06:27 PM
fordpride's Avatar
fordpride
My trans cooler is now behind the center of the bumper where the holes are
Old Feb 12, 2012 | 06:32 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
Had you thought of put late 99 spider to help air flow?
On trans cooler/ tran shop put on front of ac condenser on top where grille. That actually work BEST than factory cooler on bottom bumper that barely get air flow.
bad12jr's Avatar
bad12jr
Are those steel or aluminum ic pipes. I'd love to take those and weld them to make one piece pipes. Me a little easier to Fab
Old Feb 12, 2012 | 06:35 PM
fordpride's Avatar
fordpride
The late spider won't work it's to tall.
I'm not to worried about the cooler I'm most likely gonna be doing a ZF5 swap
fordpride's Avatar
fordpride
It aluminum pipes
Old Feb 12, 2012 | 06:37 PM
fordpride's Avatar
fordpride
If anyone need the 2" plenum boots I gave a set thats only about 3 months old you can have them. They are blue.
Old Feb 12, 2012 | 06:56 PM
bad12jr's Avatar
bad12jr
Dang it. Welp back to my first plan of making them from scratch.
Old Feb 13, 2012 | 11:07 AM
fordpride's Avatar
fordpride
I was I hopping the crappy clamps that came with the kit would hold till I get off work today well that didn't happen. I had 4 blow off in my 30 min ride to work.
P.S. These trucks make lots if smoke with out air
Old Feb 13, 2012 | 12:13 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Ain't that the truth.. Could be worse though. You could have the big BD clamps and the awesome Dieselsite boots and still be blowing boots off.... I've got a couple boots double clamped and hair sprayed to keep them on.
Old Feb 13, 2012 | 12:48 PM
jleal_21's Avatar
jleal_21
i have a friend who has some e99 spyders if anyone is interested. pm me if you are
Old Feb 13, 2012 | 01:09 PM
fordpride's Avatar
fordpride
I didn't think very many people knew the hair spray trick. I had a old guy teach me that when I worked in a big rig shop.
The clamps it came with sucks azz. Gotta get some T bolt clamps
Old Feb 13, 2012 | 01:35 PM
  #28
strokin'_tatsch
Yeah, I think my pipe isn't quite aligned right or something b/c unless I have the hot pipe double clamped and sprayed, it won't hold. I tried it with a single clamp and hair spray, blew it the first time it spooled. Tried it double clamped and no spray, blew it..
Definitely gotta get rid of those worm drive clamps you got though and get some constant torque clamps. Maybe consider welding up a couple of those joints to get rid of a couple boots too. IMO the less boots to blow off the better.
Old Feb 13, 2012 | 01:56 PM
  #29
bad12jr's Avatar
bad12jr
My thought as well.
Old Feb 13, 2012 | 02:06 PM
  #30
MHammer21's Avatar
MHammer21
Hairspray??? please elaborate. Inquiring minds want to know
