Tick in the motor
No, I used the scangaugeII to read my voltage on the ficm, the tick sounds like its coming from the front left (if your standing in front of the truck) of the motor lower half. I used to play around with my car motors but obviously I don't know anything about diesel so if it's not something simple like undoing three clips to take out the ficm I'm not even going to try playing around with things.
Well I have been in canada and am out of touch when I'm up there. Z hilton, sorry for being thin skinned, that news kinda broke my heart. I have been looking on my service manual and it doesnt address the lifters at all. If I can replace them, I might. The 4k engine from blackstone sounds ok too. I am going to start a new thread asking for the procedure.
Zhilton, about my hpop bearing thought, I was hoping the bearing in the gear strictly because of where its coming from. Prob fat chance tho huh? Or maybe the stc fitting somehow came loose and the bolts are squeaking with the pulse of each revolution of the gear. That's picturebook,,,,, grasping at straws there.
My 06' six-O,,seems to tick a little,,,but I think it is or maybe an exhaust leak,,where the exhaust manifolds bolt to the head,,,when drilling the drivers side exhaust manifold for my EGT probe,,I noticed a few exhaust ports with black sooty residue around them as in leaking somewhat,,,!!!
Also the whole Block was very crusty,,as in Rust Crust,,,about 1/4" thick,,,scraping and cleaning it was done and then sprayed with, Amsoil metal protector,,,,Check them out !!
I agree that cheezit or m-chan surely would have seen this if that was the issue. I was grasping at straws. I dont know if you saw my other post but,,,, it went away!?!?!? I dont know wether to be happy or scared. Oh and I'm sorry for being so sensitive before. Hearing that I might need a long block because of a squeak, well, I think you understand,,, but I am sorry. Btw, if I could (or knew how to fully inspect the cam) replace the lifters, I think I would give it a shot. I will take some practice pullin the engine. In my line of work, it doesnt pay to be scared of the truck. Has anyone seen that guy on ebay that is selling a plate that bolts where the turbo does and only requires one connecting point to pull the engine. I think I will be the guinea pig.
I would also like to see 500k. I should be at 470k by next weekend. 462k now. Shute, how about 600k. I just feel like I'm going to lose all my miles if I have to replace the engine. I'm so far past the point of worrying about "low miles" that I wanna stack em up as many as possible. I'm proud of em.
Steadyman, does your sound, sound like a belt squeaking after shutdown. It would squeak 3 times max after the injectors shut down. I wonder if you could put the tensioner on the kickstand without removing the belt to rule out the accessory drive system without it messing up anything. Maybe cheezit or m-chan have input on this.
Interesting I thought of the same thing
My luck it might catch and shread stuff up good IDK
If you do it let us know how it goes
#28
Yeah, I seen your post about the sound/noise has mysteriously vanished. I'm far from an expert on these engines....so I don't know if that means the final countdown has begun or it has "corrected itself" As much as we make fun of Bill Hewitt on here. He does have some interesting videos. Case in point, a needle bearing that went out on a truck with 203k miles.FUBAR 6.0 - FAILURE OF MINOR PART LEADS TO BIG REPAIR BILL - YouTube
I completely agree, your to the point that miles like you've stack on the truck so far are a bragging right. Considering I only put 20k a year on mile it will take me a LONG time to catch up if you quit driving today. So when I say I hope I get to at least half of what you've got you understand I'm not aiming low...I'm just figuring the chassis will be gone by that point.
#29
#30
