I have a 96 F 350 and just did the 6637 mod. I have noticed increased power and throttle response but have also noticed a signicant reduction in boost pressure. Is this normal?
The reduction of boost and the increase in power are opposites. They should go hand in hand. I don't see how that can happen unless your just talking about running around in town when you don't get any boost usually.
You can lose boost and gain power. A perfect example of this is when you install an intercooler.
Adding an intercooler doesnt give you anymore power. It just lowers your EGT's. I guess in theory, yes colder air = more dense air= and fuel + more air= power. BUT that difference is miniscule.
You don't even loose it then, it's just delayed until you pressurize the whole system
Well, if your turbo makes say, 20 lbs of boost and you add your intercooler and tubing, your turbo will still be making the same boost it was before, but the boost pressure will be less as its in a larger area. Your turbo doesnt make more boost to make up for it
