New here with glow plug question
Old Feb 11, 2012 | 06:46 PM
tombogue09's Avatar
tombogue09
I recently got a 87 Ford f250 6.9 IDI. I've never had a ford but have had plenty of diesels, I'm mainly a cummins guy but couldn't pass up this truck. It only has 40k miles and is in very good condition. Anyway, I bypassed the glow pug system with a push button setup. I've read that you can burn up the plugs doing this and to only use them around 5 seconds at a time. I've done some searching and have gotten mixed messages. Any help appreciated.
Thanks
Old Feb 11, 2012 | 07:17 PM
540milotalon's Avatar
540milotalon
When I had this set up on an '85 I would hold the button around a count of 15. When you use the key switch your light times out in about 10-15 seconds I think, but the relay stays energizes 1 1/2-2 min.
Old Feb 11, 2012 | 10:02 PM
Phy's Avatar
Phy
No, they don't stay on for minutes. The wait to start light comes on with the plugs for 10-15 seconds, then the wait to start light goes out (at which point you should start it), and the controller cycles the plugs on & off for another few seconds to help keep it running. After that, they're off. Watch the volt meter, and you can see the voltage drop when the plugs are energized...
Old Feb 11, 2012 | 10:13 PM
rwperkinsjr's Avatar
rwperkinsjr
I can hear my '86 click off and the light goes out in about 12 seconds at 29 degrees outside. I just went and started it to see and she hasn't been started this week at all.
Old Feb 11, 2012 | 10:39 PM
540milotalon
Won't argue, but use a hand held volt meter at the relay and it stays on a bit longer. IDI or DI.
Old Feb 11, 2012 | 10:45 PM
greywynd's Avatar
greywynd
Don't argue then. 10-15 seconds, then about 2 seconds on and 2 seconds off for 20-30 seconds after it starts to help it warm up a bit faster.
Anything longer than 10-15 seconds constant on will start burning out plugs.
Old Feb 11, 2012 | 11:09 PM
Phy's Avatar
Phy
Sorry, I should re-phrase that...
They're not supposed to stay on for minutes...
Old Feb 11, 2012 | 11:16 PM
L J Buerger's Avatar
L J Buerger
Thinking back to my farm boy days...When the mercury was above freezing, I held the glow plug switch for a 10-second count before cranking. When it was below zero, a 15-second count usually did the trick.
chillman88
31
Nov 23, 2016 09:04 AM
Ray Vaughn
Nov 23, 2014 12:29 AM
MageBeowulf
Nov 13, 2011 04:57 PM
zswiss182
Nov 12, 2008 12:16 AM
Bflodiesel
Apr 22, 2004 11:44 AM
