Bronco II Ford Bronco II
2.9 horsepower
Old Apr 23, 2003 | 10:40 AM
big88b2's Avatar
big88b2
2.9 horsepower
i know that this motor starts with 140 hp but i want to know how much could be pulled out of this little one. I was planning on boring it, high performance spark plugs wires, +4 plugs, k&n air filter with custom cold air induction. any help would be appreciated
Old Apr 29, 2003 | 08:33 AM
Bronco 1169's Avatar
Bronco 1169
2.9 horsepower
You can get a chip for it . it will help alot. all so you can get some Flow master's .
Old Apr 29, 2003 | 11:39 AM
rusty70f100's Avatar
rusty70f100
2.9 horsepower
What year is it? If its an 88 or up you should go with the 86-87 throttle body, as its bigger. Something else you might want to think about is a cam and a set of world products heads (ported of course). If you have it apart anyway to bore it, you might as well.
Edit: duh I just saw your name is big88b2, so I'm gonna guess its an 88. You should definately get the throttle body.
Old May 14, 2003 | 02:35 PM
rebocardo's Avatar
rebocardo
2.9 horsepower
The most you can probably expect to really get is 170 hp. Or you can spend the money on a 5.0 and get 250 hp right out of the crate.
Old May 22, 2003 | 12:13 PM
jcharne's Avatar
jcharne
2.9 horsepower
does the 5.0 fit right in? or what all do you have to do to do this? mine is a 5 speed. would that work with the 5.0?
