How much does tire width affect MPG?
Old Feb 9, 2012 | 09:32 PM
LeoJr's Avatar
LeoJr
I currently have a near brand new set of load range E, 235 width tires on my new-to-me four-dooor '96 F250. I'd prefer to have a wider tire primarily for looks. I'd buy a second set of rims (So I can use its load capacity when I need it.) just for wider tires for the looks and a cushier ride if it makes sense.
My question is: How much do the wider tires affect MPG? Most of my current driving is city streets and FM roads, very little freeway miles. But, I have a 16 hour each way family road trip next month and am trying to justify a smother ride. But at what fuel cost penalty?
Thanks for sharing your knowledge and experience!!
Old Feb 9, 2012 | 10:41 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Depends how wide your talking about. But if you got a 16 hour road trip coming, keep the 235's.
No difference in ride quality, wider vs skinny tires.
Old Feb 9, 2012 | 11:12 PM
RJJP's Avatar
RJJP
My old Cooper Discover 265/75R16 rode better, got better fuel economy, were quieter, had a higher load rating, and got better traction than my GoodYear 245/85R16 tires. Until I threw the tread off them. Full throttle sideways through all four gears finally killed them, and left a nice set of black marks that lasted 4 or 5 months.
Basically what I'm getting at is the tread compound and design have a much higher impact than the size, as long as you don't get ridiculous.
Old Feb 9, 2012 | 11:24 PM
deljac's Avatar
deljac
a set of 265/75/16 wont make any difference that you will notice and they look better
Old Feb 9, 2012 | 11:40 PM
Big_Al59's Avatar
Big_Al59
If your talking larger tires go with a 285/75/16, they look better (to me anyway). I didn't notice any difference in ride or mpg between the 235 or 285, the bigger ones just look better.
Old Feb 11, 2012 | 02:07 AM
xxshine's Avatar
xxshine
I thought the stock wheel bearings weren't designed to handle tire sizes other than stock. The bearings would wear out faster.
Old Feb 11, 2012 | 09:46 AM
444dieselrod's Avatar
444dieselrod
I've had 285/75/16 on my powerstokes for almost 10 years and the bearings are fine....
I did switch to some 235/85/16 for one winter and I gained almost 2mpg on my 97 diesel. I would guess a gasser would see the same.
Old Feb 11, 2012 | 10:13 AM
Big_Al59's Avatar
Big_Al59
Keep in mind that your speedometer/ odometer will be off by 2 or 3 mph when changing between the 2 sizes. Could throw off mpg figures.
Old Feb 11, 2012 | 10:29 AM
Twinmill's Avatar
Twinmill
I have 35x12.50x15 for my 1993 f150 on oversized rims and I ended up buying some 235/75/15R which are the stock size and they look rediculous.
Thom12
6.7L Power Stroke Diesel
20
Nov 10, 2014 08:55 AM
Talyn
30
May 23, 2011 02:09 PM
madrosie98
Sep 20, 2010 12:35 PM
beefey
Dec 16, 2009 11:12 PM
Big
Apr 8, 2005 07:45 AM
