water pump problems
#32
Its a 1990 I found the sensor ran out of time to check it been trying to figure out why I don't have heat. I've replaced the vacume switch on the side if the heat ac controls put a new blower motor in just because the old one was blowing week checked for vacume leaks and the only one was on the switch that I switched out with another one I guess next is a new heater core
#35
I think the best way to flush just the core would be to take it out and pump water in via garden hose. Thats what i would try before buying one, thats if you can remove it easily. If not you could probably do it while it is on the truck just unhook one hose from the core and either hook another hose on the other side or take both hoses off and fire a garden hose with full blast into it.
#36
#37
I would assume they would get clogged, people leave stuff on the dash and it can get dropped into the vent tube. If you can get to the side where it goes into the blower housing try using an airgun and shooting up into it. That may dislodge whatever is blocking it. I don't know too much about the air vent systems cause i haven't had much work to do on them but that seems like it would work.
kkrapp
05-01-2013 09:07 AM
pintoches
03-07-2010 09:16 PM
