Here is something new
Old Feb 9, 2012 | 08:03 PM
joeyd61's Avatar
joeyd61
at least I havent seen or read about this....Shifter wont come out of park with the truck running, I cant even pull it to the stearing wheel.with the switch in the off position,i can pull it in but wont come out of park....put the switch between lock and run and it shifts fine....... so put it in netural,start the truck and go......this just started after installing motor....
any ideas????
Old Feb 9, 2012 | 08:21 PM
BigAlsPSD's Avatar
BigAlsPSD
Maybe check the fuse I want to say it is 31 for the range sensor Might go to the lock out as well...I know after my last install I had to adjust the linkage.
Old Feb 9, 2012 | 08:25 PM
joeyd61's Avatar
joeyd61
I will check the fuse, but would that stop the shifter from pulling foward???
Old Feb 9, 2012 | 08:26 PM
BigAlsPSD's Avatar
BigAlsPSD
I wouldn't think so actually.
Old Feb 9, 2012 | 08:32 PM
gdunn's Avatar
gdunn
If you look under the column with the dash panel out you will see a little adjustable cable. Maybe that is it.
Old Feb 9, 2012 | 08:43 PM
BigAlsPSD's Avatar
BigAlsPSD
That little adjustable cable only moves the pointer.
Old Feb 9, 2012 | 08:44 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
How about a sensor on the brake pedal? Like if you try to move the shifter without pressing the brake?
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Hey Joey, Back step your install maybe you got something jammed up, up under the truck.
Old Feb 9, 2012 | 08:46 PM
joeyd61's Avatar
joeyd61
I planning on that in the morning
Old Feb 9, 2012 | 08:48 PM
joeyd61's Avatar
joeyd61
we looked for that today....if that was the case....what would putting the switch in the middle do with the problem......
Old Feb 9, 2012 | 08:52 PM
tdpower's Avatar
tdpower
Think there is a lock solenoid in the gearshift column that prevents from taking out of park until the brake is pressed.
On edit maybe you just need to adjust the cable at the transmission. Might sense you are in R.
Old Feb 9, 2012 | 09:16 PM
joeyd61's Avatar
joeyd61
my friend helping me thinks its the solenoid......
Old Feb 9, 2012 | 09:42 PM
woodnthings's Avatar
woodnthings
The shift lock circuit is pretty simple. Here is the diagram for you.
Old Feb 9, 2012 | 09:52 PM
mueckster's Avatar
mueckster
Unplug the wires from the shift lock actuator and it should disable the locking feature. Gear shift will move with or without key on. I did this on my brother-in-law's '95 F250 when the same thing happened.
Old Feb 10, 2012 | 10:26 AM
joeyd61's Avatar
joeyd61
Shift Lock Actuator it is.....Unpluged it and all is well..Got one on order.....
Thanks everyone....FTE is a wonderful place
Bertelrud
Mar 27, 2017 04:24 PM
mattd17
Escape & Escape Hybrid
Feb 6, 2013 01:15 PM
yamaman22
Jul 30, 2007 03:24 AM
Nomadadon
Electrical Systems/Wiring
Oct 3, 2003 07:57 PM
