ELC CHOICES
Old 02-09-2012, 05:46 PM
BIG-DADDY-F350's Avatar
BIG-DADDY-F350
BIG-DADDY-F350 is offline
ELC CHOICES
How many of you guys are using the newer Extended Life Coolants in your E99-2002 7.3's? I read another thread on some interesting facts about ELC's. I'm mainly interested in what brands are being used and any pros and cons. Thanks.
Old 02-09-2012, 06:24 PM
guitarpicr's Avatar
guitarpicr
guitarpicr is offline
I'm running it for a couple years now. I beleive that the e99 has some o-ring issues with the elc. I would check on this if yours is an early bird -Oh I got the elc concentrate from Cat dealer
Old 02-09-2012, 07:56 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
I'm running DELO in my 2002. Let it be noted that you cant run ELC in an e99 with out modifications.
Old 02-09-2012, 08:42 PM
nlemerise's Avatar
nlemerise
nlemerise is offline
I've had it in my e99 (Delo ELC) for over three years with no modifications (you are referring Trey to resealing the injector cups I assume).
Old 02-09-2012, 09:13 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
I dont know the specifics of it but that sounds about right.
Old 02-09-2012, 09:21 PM
joeyd61's Avatar
joeyd61
joeyd61 is offline
Rotella ELC in mine for over 200,000 miles....
Old 02-09-2012, 11:20 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
5 years 70K miles in the Ex.
Little over a year (IIRC) in the F250.
Stewart
Old 02-10-2012, 11:25 AM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
I've had it in my e99 (Delo ELC) for over three years with no modifications.
Neal,
Just out of curiosity what is your engine build date?
Old 02-10-2012, 11:28 AM
nlemerise's Avatar
nlemerise
April 2, 1998...14th birthday this year!
Old 02-10-2012, 11:40 AM
PaysonPSD's Avatar
PaysonPSD
Thanks.
Mar 3, 98 here. I was just wondering if there might be a time that they started using a different injector cup retaining compound on the E99s, but now I doubt it.
Old 02-10-2012, 11:43 AM
SkySkiJason's Avatar
SkySkiJason
SkySkiJason is offline
Received 1,952 Likes on 1,166 Posts
I use CAT pre-mixed ELC. Available at any CAT dealer (in every major city in the country) and runs about $10/gal.
Rotella ELC is what I usually see at truck stops. AFAIK, there is no reason these cannot be used together if ya need to top off on the road.
FWIW, we've done cups on a few e99 and OBS trucks - and that sealant sure LOOKS the same as late '99... I also have never seen pics of 'failed sealant' on e99 from ELC.
Old 02-10-2012, 12:20 PM
BIG-DADDY-F350
Thanks for the input. It looks like I should steer away from the newer cooalnts and go with the original spec. from Ford with FW-15 additive.
Old 02-10-2012, 07:02 PM
Stewart_H's Avatar
Stewart_H
Clay posted a pic sometime back. I'll see if I can find it.
Stewart
Old 02-10-2012, 07:06 PM
Stewart_H's Avatar
Stewart_H
Found it.
Originally Posted by Riffraff Performance
Here are some pics to show what happen when you use it on the incorrect year.
The red on the end is Red ELC mix with the loctite it dissolved. They had just started to push past and it was only on 3 of the 8 cups. But when we pulled them almost all turned in the head and didn't have any loctite left on them.
As Gooch say's, "To be certain, the problems found with the older type of sealant used during injector cup installation, which doesn't mix well with an OAT ELC, is enough to stop someone in their tracks."
Stewart
Old 02-10-2012, 07:33 PM
van_350sd's Avatar
van_350sd
van_350sd is offline
Changing over to Cat ELC Cooling System,
Today I got the 5 Gallons of Cat ELC Concentrate 119-5150
Strawberry-Red Coolant. The cost was $ 25.00 each,
I bought 5 gallons of the concentrate, 4 to use and one extra for stock.
The Cat ELC is rated at 6 Years or 6000 Hours or 600,000 miles.
http://www.finning.ca/_downloads/sos...t_pehp4036.pdf
http://www.altorfer.com/images/winterspecials09_web.pdf
http://www.petersonpower.com/industr...entrebates.pdf
I bought a gallon of each Restore & Restore plus 25.00 + 30.00 a gal.
I bought 42 gallons seven cases of (6) bottles/gallons each Distilled water.
I have a new Bosch water-pump, hoses, 203 stat, housing, coolant-filter,
I will take the pics and make the pdf as we do the job, and write down
how many minutes the engine cools before we drain and re-fill with water
for the next flush.
I will back-flush using the Hose-"T" with pressure and pull the engine block plugs.
A Cat Mechanic told me to use a Hose w/tap water to back-flush using the "T", it will get so much more junk out the system vs. using only the distilled dropped into a funnel/feed.
I have read where many people say the back-flush is well worth the time to do it right,
I am shooting it with the HD i-Flip Video Recorder and will UL to YouTube.
This is copied from another Forum Site:
( Mixing coolant types... - Escapees Discussion Forum )
There is a lot more than just grabbing a jug of stuff and dumping it in the engine.
2 years ago, I had to resleeve a JD diesel backhoe that used "normal" (non-diesel) green antifreeze that the SCA additives had not been added or tested (it was bought used so history is a murky thing - testing showed that the coolant was generic automotive ethylene glycol). The problem with "automotive" antifreeze is that the diesel detenations will cause cavatation and "eat" holes through the cylinder walls. Anti freeze is formulated for the use intended.
Also watch your coolant filter. Many come with SCA additives that are NOT good to mix with the Organic Acid Coolants (ELC's)
With a $15,000 ~ engine I am going to take a chance on bad coolant?
Let me pose another question. Why do you use diesel oil (Rotella, Delvac) with a API (American Petroleum Institue) oil rated for C* (G thru J+) instead of S* (F thru I+)? C rating is for Compression ignition engines, S is for Spark ignition engines
Orange Might be Dexcool - Article on some Dexcool stuff (gist of the article is correct but he is off on some points) - http://flashoffroad.com/Maintenance/...antifreeze.htm
Ford does mention it in the diesel supplement book (does not highlight it though). It will eat a GM block. Most take the attitude that if you buy a diesel - know what you are buying.
Link to some of the different colors - http://www.recochem.com/files/downlo..._Guide_CAN.pdf
Here are some links to the RED ELC (Extended Life Coolant)
Chevron Delo HD ELC (concentrate PN 227804/Texaco concentrate PN 227997):
http://www.chevron.c...wheretobuy.aspx
Shell Rotella HD ELC (concentrate PN 9404106021):
http://www.shell.com/home/Framework?...heretobuy.html
CAT HD ELC (concentrate PN 119-5150):
http://www.cat.com/c...out?m=39542&x=7
International Fleetrite HD ELC (same stuff as Shell Rotella HD ELC):
http://129.33.208.17.../locator-it.asp
Mobil Delvac HD ELC:
http://www.host.exxonmobil.com/chann..._directory.jsp
Fleetguard ES Compleat OAT HD ELC (concentrate PN 2780):
http://www.cumminsfiltration.com/wrl....do?_locale=en
Peak Final Charge HD ELC:
http://www.peakantif...orelocator.html
Prestone Heavy Duty Extended Life:
http://www.prestone....php?product=afc
Detroit Diesel Power Cool Plus HD ELC (concentrate PN 23519397)
Zerex Extended Life Extreme HD ELC (concentrate PN ZXED1)
1-800-832-6825
Of course there are lots of other brands and off-brands available locally to folks at truck/equipment dealers, truck shops/stops, part stores, equipment rental shops, jobbers/distributors, and so on.
Quick Reply: ELC CHOICES
