Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
About to replace a tone ring, Strut bolts or ball joint?
Old 02-09-2012, 09:34 AM
mleichtle's Avatar
mleichtle
mleichtle is offline
To get the axle out some of the walk throughs removed the ball joint, but most of you removed the strut bolts. Do the strut bolts adjust the alignment? If so, How did you mark em to get em back in straight? None of guides mention get an alignment done after this job.
Old 02-09-2012, 06:19 PM
critterf1's Avatar
critterf1
critterf1 is offline
I always remove the ball joint.
Old 02-10-2012, 07:39 AM
Dan Robertson's Avatar
Dan Robertson
Dan Robertson is offline
Removing the lower strut bolts do not effect the front end alignment, at least if it does, I have been lucky 3 times. (2005 AWD)
Old 02-10-2012, 01:05 PM
rickfar's Avatar
rickfar
rickfar is offline
I did tone ring and removed lower strut bolts and replaced sway bar links also and when it was said and done alignment changed a few degrees and had it done at NTB had previously bought the 3 yr alignment package for like 120.00 so it cost nothing for them to put her on the machine a tweek it. Tire kingdom/NTB alignment package is well worth the 120.00 for 3 yrs of alignments if you do any wrenching on these escapes. JMHO
FordTruckChuck
1997 - 2003 F150
09-19-2015 07:05 PM
Hotrod_ace
1983 - 2012 Ranger & B-Series
05-06-2013 03:05 PM
40LUTZAG
1997 - 2003 F150
04-16-2008 02:57 PM
thomc
12-10-2007 09:46 PM
Quick Reply: About to replace a tone ring, Strut bolts or ball joint?
