About to replace a tone ring, Strut bolts or ball joint?
To get the axle out some of the walk throughs removed the ball joint, but most of you removed the strut bolts. Do the strut bolts adjust the alignment? If so, How did you mark em to get em back in straight? None of guides mention get an alignment done after this job.
I always remove the ball joint.
Removing the lower strut bolts do not effect the front end alignment, at least if it does, I have been lucky 3 times. (2005 AWD)
Originally Posted by mleichtle
(Post 11407398)
