I've got a 2010 Ford F350 crew cab long bed 6.4 4X4. Question- is it possible/ok to put 325/65R18 on my stock rims. Any input would be appreciated.
Thanks in advance
thats a big jump and u will have to understand that ur tires are gonna wear alot more in the middle. it can be done though. the highest i would go would be 305s. need some pics tho.
What brand tires you talking about? Usually the manufacturer provides a detailed spec sheet on the website. Check there...and as already mentioned...I don't think so.
Now that you are a Member edit above post, click go advanced, then click the attachments (Paperclip) click up load, and use that file, then click attachments again, and you will see the attachment.
Those Goodyears are 325-60-18s on the stock rims. Truck is an 08 F250 4x4 gasser. I bought he truck just the way it sits in the picture. Once the tires are junk, I don't know if I'll stay with that size or do something a little different but for now, they seem to work fine. No issues with handling or ride with that size on there. The tires seem to be wearing fine also. I run them right at 65psi all the way around. They were at 60 when I bought it. I don;t know how long the tires have been on the truck though so I can't speak to tread longevity. They look good though!
They do look nice do you have a side view or your truck?
