Low boost numbers
Old Feb 8, 2012 | 06:31 PM
Cavstoy's Avatar
Cavstoy
Low boost numbers
I bought a 1986 with a hypermax on it. It also has the bb code injectors. 4" exhaust turbo back. It seems like it takes all kind of throttle to get boost to register on the guage. Then it maxes at about 8psi. That its climbing a hill at 65mph wide open. Kind of has me stumped. It isnt blowing any smoke (not that I want it to). How do I check for a boost leak?
Old Feb 9, 2012 | 09:19 AM
snaponprofile's Avatar
snaponprofile
Just make sure all the connections are tight. If you want to be totally sure, just remove all the rubber part that air travels through and spray them down down with brake parts cleaner really good. That should eliminate your problems. On another note, 8 psi isn't bad for a IDI, what do your EGT's read when you are at 8 psi??
Old Feb 9, 2012 | 09:53 AM
IDI guy's Avatar
IDI guy
Yeah I would make sure you don't have an air leak but I only run about 10 psi then my waste gate opens 12+ is the danger zone these engines are high compression (21.5/1) low boost so 8 is ok if you don't have any air leaks you could adjust your waste gate a little I bet and get her up to 10 psi. Be carefull too much boost on a stock set up and you will be putting in new head gaskets.
Old Feb 9, 2012 | 09:54 AM
Cavstoy's Avatar
Cavstoy
Egts are reasonable. They hold at 10-1100 if I stay in it for a while, never go any higher than that though. I guess 8 isnt my complaint, but the rpm requires to get that is. Like I said, I only see that number at wot, at about 3k rpm. I would like some boost down low if that is possible.
Old Feb 9, 2012 | 09:55 AM
Cavstoy's Avatar
Cavstoy
I didnt think the hypermax was wastegated?
Old Feb 9, 2012 | 10:00 AM
IDI guy's Avatar
IDI guy
Oh I was thinking it was. Maybe bigger exheust but some of those non waste gated rigs are made to run low boost and if you are hitting 1100* now I would not give it any more fuel to get more boost
Old Feb 9, 2012 | 10:08 AM
Cavstoy's Avatar
Cavstoy
I am wondering about my pyro actually. I think ot is out of whack. Always reads higher than it ought to. At idle it reads 450 but my IR thermometer reads 245 at the same site.
Old Feb 9, 2012 | 10:17 AM
snaponprofile
Yeah, thats the non-gated turbo's. If you were towing, egt's would be higher and boost would be around 12-13 i'd say.
Old Feb 9, 2012 | 10:24 AM
Cavstoy's Avatar
Cavstoy
Yeah. Maybe I will swap something that breaths a little better in one of these days.
Old Feb 9, 2012 | 10:39 AM
snaponprofile
You mean swap a better turbo in? For the cost that would set you back, you should put in a intercooler to lower your egt's so you can increase the fuel on your old pump or upgrade to a DPS pump. I am upgrading to a DPS pump soon because I am just about out of fuel on my non-turbo fuel pump. The dps pumps are better because they are set to input the fuel to spool up the turbo.
From their website......
"........only good if the engine has either a factory or aftermarket turbocharger. We readjust the fueling and timing curve to take full advantage of a turbo, and normally raise the governed RPM to 3800. The max fuel delivery capability of the pump is also raised. Although we can do a turn-up on any rotary pump, the ideal pump to use is a "XX31" model, found in the '93 - '94.5 idi. We can bring an "XX29" pump up to the same fuel delivery, but the price will go up due to the extra machining involved. Maximum gains are seen when a matched set of injectors are used."
Diesel Performance Specialists, Inc. - The Diesel Performance Specialists
Old Feb 9, 2012 | 11:51 AM
IDI guy's Avatar
IDI guy
Looks like you are in for a new pyro.
Old Feb 9, 2012 | 04:24 PM
Cavstoy's Avatar
Cavstoy
Yeah. Any suggestions on a cheap one? I dont feel like dropping a ton on it. The one I have in there now is the hypermax
Old Feb 9, 2012 | 04:53 PM
snaponprofile
GlowShift 52mm Tinted 7 Color Celsius Exhaust Gas Temperature Pyrometer Gauge | eBay
INSTALLED:
Old Feb 9, 2012 | 05:28 PM
IDI guy's Avatar
IDI guy
Nice I like that cluster does it come in blue or can you paint it to match?
Old Feb 9, 2012 | 07:31 PM
Cavstoy's Avatar
Cavstoy
Thanks for the pic and link. Looks like a decent product at a reasonable price. Does it seem accurate? Where did you place your probe, snapon?
