Need a break down or schematic on ford C6 4x4 trans please
Feb 8, 2012 | 04:16 PM
I am swapping a 351w trans C6 into my '78 Bronco, and I need something to show the parts breakdown of the c6.
Basically, I need to know what need to be changed to make the 205 fit behind the newer c6.
I am taking off the 1356
Feb 8, 2012 | 04:24 PM
I've always heard all the ford transfer cases will swap until you get up to 99 or so.
Feb 8, 2012 | 04:53 PM
It should bolt right up cause as far as I know they had c6s in most of them old broncos
Feb 8, 2012 | 10:24 PM
Quote:
Originally Posted by
bashby
88 F-350
well, the spacer between the case and trans is longer for the 205, so I figured the shaft had to be longer also.
I have not yet pulled the bronco trans.
Feb 9, 2012 | 07:43 AM
I've always gone to Ford and they're good enough to print out whatever schematic or blowup requested. They have the online Mitchell repair manuals.
Feb 9, 2012 | 10:35 AM
xxshine
Well, i was hoping that maybe someone here had it, because by the time I get off work, the parts depo is closed at ford.
Feb 11, 2012 | 11:26 AM
no one has one? I can only find 2wd online so far.
Feb 11, 2012 | 11:44 AM
The only difference between 2wd and 4wd is the output shaft and rear housing.
Feb 11, 2012 | 03:23 PM
Two different output shaft lengths used in the 4x4 C6. One is 15 3/8in and other is 18 1/2in.
rsalter66
Aug 30, 2007 08:25 PM
drwitzka
Feb 16, 2005 12:35 PM
TKONO
Jan 18, 2003 11:07 PM
4x4 ,
73 ,
79 ,
86 ,
brake ,
breakdown ,
c6 ,
diagram ,
ford ,
oil ,
schematic ,
skematic ,
trans ,
transmision ,
transmission
