Bronco II Ford Bronco II
performance overhaul
Old Apr 22, 2003 | 10:05 PM
big88b2's Avatar
big88b2
im about to tear apart a 2.9 and build it from ground up. While the block is apart, i was going to have it bored and have a bigger cam put into it. I need to know how big should i bore it and where can i get the bigger pistons. And could i get a cold air kit for it?
Old Apr 23, 2003 | 07:06 PM
matthews_56's Avatar
matthews_56
For less money you can buy a 4.0L, which is a 2.9 that has already had all the work done to it. For the most part it slips right in. Check out jamesduff.com for more info.
