Just want to hear your all's advice on how my motor is tuned at the moment.
I'm new to the 400m so just just checking.
I have the idle set to 800 ish rpm
Timing set at 0 deg.
Just rebuilt the 2bbl carb, and have the idle mixtures screws set out to 3.5 turns.
Its running at about 18 19 hg on the vacuum gauge.
New oil with plugs and wires,cap and rotor and air filter, fuel filter.
Its really peppy at the moment gets up and goes pretty quick, no pinging or knocking.
It starts with one pump on the pedal and doesn't diesel.
I do have one question tho, on the sticker on the valve cover it says to time to 14 deg before.
What would be a good degree to help fuel mileage but keep power?
With today's gasoline, 12 degrees BTDC is about right. The idle should be down around 650 RPMs. Uses less gas when idleing slower. Adjusting the timing may get your vacuum up to around 20-21.
My engine always started quicker when it had a carb on it versus now that it is fuel injected. Only difference really though is I don't have to pump the pedal. I guess the sensors have to tell the computer what to do before it starts.
You need some timing advance to allow the fuel/air mixture time to fully ignite, with it set at 0*, it's not fully ignited until the piston is halfway down the bore, you've lost half the available thrust. The higher the rpm, the more timing advance is needed to get the full thrust.
Thanks for that bit of info, helps me know my motor a bit more.
Will advancing the timing make it idle any different?
And will it help improve fuel mileage?
OK double checked my timing again today, what i thought was 0 degrees was actually more in the 12 to 14 degrees mark.
When i first checked the timing all i could see by the yellow mark that's on the crank pulley was a 0, who ever marked the pulley made a huge mark.
So i cleaned the timing marks to where i can see, and sure enough its at about 12 degrees.
So i went to see if i could get any higher on the vacuum gauge.
Here is what i found out, when i screwed both mixture screws in all the way, the truck never died till i hit the throttle.
My question is, isn't that a sign of a bad power valve?
I can get it to the 20 hg mark, but with it idling at 1000rpm, which is to high.
At 850 ish it hangs around the 19 hg mark, course its only 21 degrees here today, so i don't know if that has anything to do with it.
You want it idled high enough in neutral so that it will still idle in gear when you shift it into gear and at the lowest rpm it will idle in gear. This is how I do it. I've never used a vacuum gauge to do it.
Just me, but the choke is the first thing I completely remove from a carb. Never seen one that actually worked as intended. I prefer to baby the throttle a few minutes (at most) instead of relying on something that's unreliable.
Can't answer that. Never had a P/V go bad. Usually when the mixture screws are unresponsive, the throttle is open too far, exposing the transfer slots in the throttle bores, this puts the carb into the transition circuit, making the mixture screws unresponsive.
Well found out my choke is keeping my motor to rich at idle, hence why it didn't die when I screwed the screws in.
I ordered a new choke cap, I will post what I find.
