1978 - 1996 Big Bronco
having problems any help?
Old Feb 27, 2012 | 03:48 PM
93broncoboy's Avatar
93broncoboy
Would u think it could be an o2 sensor or the map sensor?
Old Feb 27, 2012 | 04:12 PM
93broncoboy
Well i wouldnt be pulling codes like that if it was one of them. So how hard is it to change a wire harness?
And the numbers were different but its the same problems as before and same year everything bronco could it just happen that i got the wrong one and its just causing the same problems?
It seems like everytime i change a part on it; it runs fine and then comes back to these same problems.
Fuel pump: ran fine for about 2 weeks
2nd fuel pump: 1 month
Different pcm: 1week
Old May 11, 2012 | 03:27 PM
Hawk180's Avatar
Hawk180
I know its a bit late for this conversation, but I had a 94 F150 that had the same kind of problems; throwing several codes, etc. It turned out to be bad grounds. The engine was not properly grounded to the rest of the chassis. The larges circuit on the truck is the ground, so if it is bad, many problems.
luckkyd
16
Mar 26, 2020 02:30 PM
2006powerstroke90
Feb 8, 2012 01:25 PM
StephenH
Electrical Systems/Wiring
Dec 16, 2006 04:57 PM
Jtanner76
Feb 8, 2006 10:02 AM
01silvergt
Jul 13, 2005 02:08 PM
