New battery drained...Help
Old Aug 29, 2014 | 03:22 PM
  #31
Benztechnc's Avatar
Benztechnc
Originally Posted by GT40NUT
... I tapped the starter with a hammer and it started right up. Ok I get the starter rebuilt,starts fine. A few days later...wont start after sitting a couple days....
Just an observation, but this all started after replacing the Starter with a Rebuilt starter Correct? Perhaps it's Draining through there?
Just a thought...
Old Aug 29, 2014 | 04:12 PM
  #32
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
No power passes to the starter except if the solenoid is engaged.
If it is a PMGR starter the cable may be chafed and grounding to the block or frame.
Old Aug 30, 2014 | 05:40 PM
  #33
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
FWIW, all, a quick and dirty check for bad diodes in your alternator. With the engine off and cooled down completely (like overnight) open the hood and check the alternator temperature with your hand, if it is hot or noticeably warmer than everything else, the diodes are bad.
I found I had already told you this one a while back. I do have the 1996 EVTM as my truck now has 1996 wiring harnesses in it. If you pull all the fuses in the underhood box, it will kill all power to inside the truck including the underhood light as it feeds from the courtesy lamp circuit. There is even a radio memory fuse in there.
Last edited by 85lebaront2; Aug 30, 2014 at 05:46 PM. Reason: Additional information added.
aviatorcal
Feb 23, 2013 09:16 AM
79F-1504x4
53
Mar 3, 2011 01:53 PM
gweeds
Mar 30, 2008 08:40 AM
bobznnm
1983 - 2012 Ranger & B-Series
Jul 23, 2006 09:09 PM
97 RED PSD
1997 - 2003 F150
Dec 21, 2005 12:01 AM
