Sponsored by: Real Truck
Front Hubs
Old Feb 5, 2012 | 03:57 PM
AOGF350's Avatar
AOGF350
Front Hubs
How hard is it to replace the front hub assy? Any thing I need to look out for? Any special tools? Also can you replace just the bearings or do I really need to buy the whole hub? Thanks for any help that can be offered :-) Oh yeah it's an 05 350
Old Feb 5, 2012 | 07:43 PM
h20thief's Avatar
h20thief
I have an 02 250 and just replaced ball joints. I checked the bearings while they were out and looked good. My research and assistance from the forum says its not a servicable part so replacing the hub assembly is the only option. Not hard to do and you can follow the instructions from Racerguy from his ball joint how to post. It has great pics and step by step instructions are spot on.
A good set of snap ring pliers and the bigger the better will help get the retaining ring out once you pull the locking hub, if I remember right. I'm no mechanic but it only took 1 day from start to finish to do both sides. Good luck.
Old Feb 5, 2012 | 09:44 PM
AOGF350's Avatar
AOGF350
Thanks for the info. It will be a fun project tomorrow :-)
Old Feb 6, 2012 | 12:39 PM
arto_wa's Avatar
arto_wa
Unit bearings
There is another choice; replacing the unit bearings with a serviceable bearing conversion kit from Dynatrac or Spyntec - I did that last summer on my 1999 350 4x4.
They should have kits for 2005 F350, check it out.
Old Feb 6, 2012 | 12:45 PM
arto_wa's Avatar
arto_wa
Unit bearings
motochris
Feb 29, 2016 11:55 AM
brady000
Feb 10, 2016 03:33 PM
Chequamegon
Oct 5, 2011 01:04 PM
meier63
Aug 18, 2011 10:00 AM
Grey Fox
Aug 6, 2004 02:15 PM
