Sterling swap
Old Feb 5, 2012 | 01:41 AM
rangergirl94's Avatar
rangergirl94
Sterling swap
How difficult is it to put a sterling 10.25 into my 93 f150 I have the axle out of 95 f250 my truck is sc 4x4
Old Feb 5, 2012 | 11:48 PM
rangergirl94
Im building a pulling truck and the 8.8 was already toast
Old Feb 6, 2012 | 12:00 AM
RJJP's Avatar
RJJP
Depending on the rear suspension (3" vs 2.5") or if you're transferring the leaves to it should bolt up, different U-joint though.
Old Feb 6, 2012 | 12:27 AM
rangergirl94
I have 3 inch springs will the stock drive shaft work with just a different u joint
Old Feb 6, 2012 | 08:12 AM
Bronkenstein's Avatar
Bronkenstein
I had a 96 Bronco and put a Sterling under the rear. It went right into place. Used f350 leaf springs and the stock driveshaft with 1 of those conversion ujoints.
Old Feb 6, 2012 | 08:40 AM
Edgethis's Avatar
Edgethis
You will have to use a different U-joint as mentioned but everything should bolt right up including the Sensor on top of the diff.
Wouldn't it be better to find a 250-350 to build up as a pulling truck? Maybe I'm thinking something different though.
Old Feb 6, 2012 | 09:30 AM
GNR22's Avatar
GNR22
I've helped build quite a few pulling trucks...what exactly are you building up?
Old Feb 6, 2012 | 12:23 PM
rangergirl94
F150 4x4 im just building it because im board and have the parts lol I dont care if I win or not just ideas
Old Feb 6, 2012 | 12:31 PM
Diesel_Brad's Avatar
Diesel_Brad
A 1/2 ton is FAR from the ideal pulling truck
Old Feb 6, 2012 | 01:29 PM
Edgethis's Avatar
Edgethis
Well if you swapped the rears then of course you'd have different bolt patterns and would need different rims front/rear. Unless you swapped the front to 8 lugs also.
I agree that a 1/2 ton truck isnt a great start for a pulling truck.
Old Feb 6, 2012 | 02:12 PM
rangergirl94
Just building it out of an idea I dont care if it breaks or loses lol. I normally pull every year with my dd f150 and places in the top 5 every year
Old Feb 6, 2012 | 03:15 PM
rangergirl94
The sterling is 4 inchs thicker will the stock drive shaft eat that?
mustanginca
Jan 29, 2011 07:17 PM
wolfe1104
Mar 4, 2006 10:58 PM
jmteam6
Sep 11, 2005 10:59 PM
sacf250
Offroad & 4x4
Jan 31, 2005 11:40 AM
Franken-Truck
Oct 4, 2003 11:10 AM
