Entry keypad on drivers door
Old Feb 4, 2012 | 09:52 PM
Andrew010's Avatar
Andrew010
I came home tonight and shut down the truck. Went back out in the garage awhile later and noticed the light on the keypad was still on. I've tried everything I can think of including unhooking both batteries and still can not get the light to turn off. Truck running, headlights on, no matter what the light is still on.
Anyone have any ideas? I'd like to get this corrected.
Thanks!
Andrew
Old Feb 4, 2012 | 10:43 PM
PITS's Avatar
PITS
Check to make sure one of the buttons isn't mashed under the bezel.
Old Feb 4, 2012 | 10:51 PM
Andrew010's Avatar
Andrew010
Already checked that too.
I also noticed the parking lights aren't turning on when I open the door either.
Old Feb 4, 2012 | 11:19 PM
Fontana's Avatar
Fontana
You lifted the suspension, modified the intake, modified the exhaust, removed a major component of the exhaust, and used an aftermarket tuner. With all the things you have done to your truck you're upset about a keypad light???? You're lucky it still runs!
Old Feb 4, 2012 | 11:29 PM
GCLL's Avatar
GCLL
I just had my keypad replaced under warranty because a bulb burned out. The bulbs can't be changed. Invoice said $150
Old Feb 5, 2012 | 06:48 AM
ruschejj's Avatar
ruschejj
I agree, chill out man. Things happen. Might just be the driver "door open" switch or something similar. Could be the relay that turns on the parking lights too.
Old Feb 5, 2012 | 09:22 AM
Andrew010's Avatar
Andrew010
Little wound up huh? Also, none of the things you stated would have anything to do with the keypad light on the door....
I could care less about the keypad light. Obviously something is wrong since the keypad light is stuck on and the parking lights aren't coming on when the doors are opened. Would just like to have it fixed, that's all.
We'll see what the dealer has to say about it on Monday I guess. I thought maybe this had happened to someone else before, guess not.
Thanks again guys! This is a fantastic forurm.
Andrew
Old Feb 5, 2012 | 09:41 AM
Fontana's Avatar
Fontana
I'm sorry I can't help you on this or at least point you to a method of elimination. Just saying....you did a lot of stuff. Your issue's root could be electrical or could be a conflict in the computer.
I am wound up. I get irritated when people do all these things to their trucks and get upset when they don't function properly.
Old Feb 5, 2012 | 09:49 AM
Andrew010's Avatar
Andrew010
I'm not upset with the truck because of this, I would simply like to get this problem corrected so it doesn't drain the batteries when the truck isn't running.
My apologies if I came across as upset.
Old Feb 5, 2012 | 10:01 AM
dschuffert's Avatar
dschuffert
Let us know what you find out from the dealer. I have been thinking about this since you posted it and can't logically think why just the keypad light would stay on, other than some kind of short across two wires somewhere. Other lights should go on and off with the keypad such as the dome, etc. I hope it is something simple where we all end up saying, "Ah, I wish I would of thought of that".
Old Feb 5, 2012 | 10:50 AM
brandon4's Avatar
brandon4
Mine does that off and on. Never have had it looked at. Oh, and I have a lift, intake and my truck is sometimes dirty........
Old Feb 5, 2012 | 01:36 PM
Glockin' Bob's Avatar
Glockin' Bob
Thanks!
Andrew
How long did you have the batteries disconnected? I've heard different stories on how long it takes to get a reset, perhaps someone else can chime in?
Old Feb 5, 2012 | 01:54 PM
6.7Fan's Avatar
6.7Fan
Relax. The dude is just asking a question. Whats the big deal?
Wish I could help.
Old Feb 5, 2012 | 03:00 PM
Snakedriver's Avatar
Snakedriver
I noticed this samething this morning. I think the key pad has some sort of glow in the dark quality. However, Im quite sure that the actual light(s) was not on.
Leo
Old Feb 5, 2012 | 04:50 PM
Andrew010's Avatar
Andrew010
My lights are actually on. No two ways about it, the lights are definitely on.
Dealer can have it tomorrow and I'm sure they'll figure it out. Hard to say what it'll cost, but it'll be fixed either way.
