Radiator recondition
Old Feb 4, 2012 | 06:01 PM
79silverstreak's Avatar
79silverstreak
I'm just about to get my cleaned up 400 block back from the machine shop. While every thing is going to be brand new, I'm going to reuse the radiator, the only problem is all of the corrosion in the cores. I would hate for all of that corrosion to be cycling though the clean engine. Would CLR work? Thanks
Old Feb 4, 2012 | 07:18 PM
montana_highboy's Avatar
montana_highboy
You could have the radiator boiled and rodded for under $100 or just buy new for under $300, either option is a pretty small investment towards protecting your freshly milled motor.
Old Feb 4, 2012 | 07:31 PM
turbohunter's Avatar
turbohunter
^x2^
Don't mess around.
Old Feb 4, 2012 | 08:10 PM
bamaf150's Avatar
bamaf150
I was going to have mine rodded out, providing that it could be done, radiator shop said to bring it to them and let them see it was in good enough shape; was going to be around $80 if possible. Instead I wound up buying a new one for $209, a trip came up and I didnt have the time to mess with it.
Old Feb 5, 2012 | 08:23 PM
79silverstreak
Thanks for the advice, does anyone know of a shop that can perform this in the north GA area?
Old Feb 5, 2012 | 10:44 PM
stephen.south's Avatar
stephen.south
I just tried cleaning my entire system out with vinegar. It cleaned out all kinds of sh**. You'll have to flush it several times, but you could probably just take the radiator and lay it flat and fill it with vinegar and leave it over night. then flush it in the morning.
Old Feb 5, 2012 | 11:00 PM
brian1080's Avatar
brian1080
If you take it to a shop, do they clean/strip it inside and out? I've got my big radiator for my 460 that is in perfect shape, it just needs a new paintjob. I figure if they will clean/strip the whole thing, I'll just repaint it after and have a new radiator.
Old Feb 5, 2012 | 11:26 PM
bamaf150's Avatar
bamaf150
A good shop will paint it after they recondition it, ask them.
Old Feb 5, 2012 | 11:29 PM
brian1080's Avatar
brian1080
cool, thanks. I'll go to our two local shops and see what they'll do.
Old Feb 22, 2012 | 08:06 PM
79silverstreak
Well I went to a local auto shop to have them freshen the radiator up. The one man, I spoke to, didn't know If they could or not. He asked the year of it and went to get the radiator guy to come out and take a look at it. Turns out, this guy don't even have to see it to be able to determine the condition(he must be physic), I thought it was in pretty good condition, minus the contaminates inside. The man I spoke to conveyed that it was too old. Well maybe they're right, only now I'm still in the same position, Is there a home flushing remedy, or will I have to fork out more money for a new one?
James
Old Feb 23, 2012 | 12:50 AM
brian1080's Avatar
brian1080
I'd check another shop, I went to our local shop finally the other day and they told me it would be $75 for a flush/check/strip/paint. Hopefully I'll have it dropped off in a week or two.
Old Feb 23, 2012 | 05:42 AM
Sleepy445FE's Avatar
Sleepy445FE
James
Find a new shop. My local guy knew what mine was as soon as he saw it (the heavy duty Super Cool radiator) and was in no way put off by it. He had a high opinion of the old sucker and was happy to work on it. He boiled, rodded, repaired 13 leaks lol, and painted it. Looked and worked like new when he was done. I got all this for FREE! being he is a friend of a friend, but still he had no problem fixing it (turnaround of 2 days). Avoid the psychics and find a new shop that can give a real assessment of your stuff.
triumph1200
1947 and Older Ford Trucks
Mar 8, 2017 08:47 PM
frostysdriver
50
Dec 27, 2009 08:43 PM
terran05
Oct 1, 2006 10:09 PM
CLASSICF100
Jul 14, 2003 04:24 PM
