1978 - 1996 Big Bronco
Oil Change problem.
Old Feb 4, 2012 | 04:50 PM
84tanbroncoII's Avatar
84tanbroncoII
Oil Change problem.
Hi guys,
extremely novice question here, but I bought an 84 ford bronco II about a month ago, and when I went to change the oil today, I couldn't find where to put the new oil in. There is no obvious oil cover and I surely don't want to guess. Anyone know where it is? I attached some pics to see if anyone could just point it out to me. I've never had this problem with any other truck...
Thanks!
<a href="http://tinypic.com?ref=24qsktj" target="_blank"><img src="http://i40.tinypic.com/24qsktj.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
Old Feb 4, 2012 | 05:38 PM
AzPete's Avatar
AzPete
This is full size Broncos....might try the Bronco ll pages.
Old Feb 4, 2012 | 05:39 PM
b4hntn's Avatar
b4hntn
I would guess the orange thing with the hose going to the air filter that is between the camera and dip stick in the second picture.
Old Feb 4, 2012 | 05:55 PM
critterf1's Avatar
critterf1
The crankcase breather is also the oil fill.
Old Feb 4, 2012 | 08:17 PM
ErrorS's Avatar
ErrorS
aww, the Bronco2 engine compartment is cute.
Old Feb 6, 2012 | 02:35 PM
roosplash's Avatar
roosplash
The yellow cap on the driver's side cover. The other two pics show what is left of the heat riser that would have connected to the factory air filter housing
Old Feb 6, 2012 | 05:34 PM
Edgethis's Avatar
Edgethis
Wow, that motor is small. Almost lift that out by hand, unlike my obese 351w...
Old Feb 6, 2012 | 08:17 PM
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
x2 on the orange oil breather cap. With that removed, you pour your oil directly into the engine.
Jim
Old Feb 7, 2012 | 04:26 AM
BASHAM's Avatar
BASHAM
Like everyone else has said tge orange breather on you valve covers pull that out and fill it will probably be in there pretty good with an old rubber grommet just pull twist and wiggle she'll come out
acwatkins
6.2L V8
Apr 12, 2018 07:51 PM
Resendiz
Oct 16, 2015 01:13 AM
creich68
2009 - 2014 F150
Feb 18, 2013 06:13 PM
rhino_160
Jan 10, 2008 10:00 AM
Monsoon
Dec 30, 1999 03:47 PM
