New Ignition
Old Feb 3, 2012 | 06:57 PM
fordnurse's Avatar
fordnurse
New Ignition
I have read from other posts on the forum that an easy upgrade to your stock motor is new ignition..How much is a standard ignition upgrade?? What includes in an upgrade?? an ignition module...when you get a new ignition module do you have to buy a new distributor in the process??
Old Feb 3, 2012 | 07:11 PM
fmc400's Avatar
fmc400
MSEE
Easy may be true, but "worth it" is another story.
There is not a great deal of merit in performance ignition. The money goes a LOT farther with items like carburetors, intakes and exhaust. For a specific plug gap, there's a certain range of secondary voltage that it takes for the spark to jump. The factory Duraspark setup does that just fine. All the science around fancy terms like "double-sparking" or "capacitive discharge" does not really net you much on stock or mild motors in my honest opinion.
To answer your actual question, though, it depends how much you want to spend. You can get ignition modules that are compatible with the Ford hall effect sensor in the distributor. You can also get completely new setups that have a new distributor and module (in some cases the module is part of the distributor).
A cheap and quick upgrade that many misinformed people do is to buy a "performance" or "hot" coil and use it with an otherwise stock ignition. The power transistor in the Duraspark module is rated to handle the current drawn by the stock setup. A "performance" coil with lower primary winding resistance can strain the module, and there's hardly any difference in performance in the first place.
Old Feb 3, 2012 | 07:14 PM
fordnurse's Avatar
fordnurse
thanks thats what I needed to know!
Old Feb 3, 2012 | 09:48 PM
Blue and White's Avatar
Blue and White
Agree... the Duraspark system handles .040-.045" plug gap fine which is plenty for a stock or mildly modified engine. Little/no gain in changing it. Is it worth making sure plugs/wires/cap/rotor are in good shape... very much so. Also, should I ever need to change the Duraspark box in a non-emergency situation, I'll follow the advice of many on this forum and use a FOMOCO box... not aftermarket/re-pop as these seem to be problematical.
raven3
Jul 22, 2014 09:45 AM
skattnig
Jan 17, 2008 01:23 PM
cjbronco
16
Oct 12, 2005 03:13 PM
ClatonK
Electrical Systems/Wiring
Jan 26, 2004 01:48 PM
f100guy
Oct 5, 2003 12:21 PM
