Not sure if its possible on that model, but you did replace the ignition switch and not just the tumbler where the key goes in, right?
I actually replaced both because the tumbler was worn out and you could start it with a screw driver but yes I did replace the electrical part of the switch.
Thanks for the helpful diagram fasthauler. I was sure I put that jumper on correctly but I will try again. I figure it's common sense but just to be clear it's one to the + side of the battery and one to the + side of the coil right?
I'm going to be honest, I have no idea what you just said. What is the voltage divider? How do I force the points closed or short them across? You want to measure what with my multimeter? Sorry I'm an idiot.
My fault, I should have explained myself more.
Basically you're just making sure that the voltage drops down to the expected level with the key in RUN. With the key in RUN, the coil is connected to the power source through a ballast resistor (resistor wire in the dash harness). When the circuit is complete, the voltage seen at the coil positive terminal is lower than it would be if you connected the coil straight to the power source.
When you checked the voltage at the coil with the key in RUN and saw 12 volts, the points would have been OPEN. This is because no current flows through the coil and hence the ballast, so there is no drop across the ballast. If you were to CLOSE the points, current flows through the circuit, and there is a voltage drop across the ballast resistor. What's left shows up at the coil. This principle is called voltage division.
You just want to check that the voltage goes down to the correct level with the points CLOSED. You can close the points by physically pushing them shut like the distributor shaft does as it rotates. Or you can physically short them across with a screwdriver. The points are just a switch. I mentioned to be careful when you OPEN the circuit afterwards because the coil will have been energized.
GFW had another great idea to temporarily jump power straight to the coil just to make sure the engine runs, because if it doesn't, then that will steer where to go next. Check what you did against fasthauler's diagram to make sure you set it up correctly.
Originally Posted by F-250 WARHORSE
Would it be too big a stretch to look at a ground that is closed through the starter but when starter is kicked out the ground breaks and the ignition circuit opens?
That's an interesting idea. I can't think off the top of my head how that would happen, but it's something to think about. Maybe to be safe, make sure the ground wire in the distributor (that connects the stationary base plate to the moveable breaker plate) is intact.
Thanks for the reply. I cant really mess with it today but I am off work tomorrow and will try all of your suggestions. I'll get back to you sometime tomorrow. Thanks again for everyone's help.
Going along with fmc400's suggestion to check ground in the distributor. Make sure the ground strap from engine to firewall is in place. I have had funny things happen I couldn't explain due to that being missing. Curious to see where this problem is. Last time I had this problem with points, it wound up being point gap was too wide, messing with the dwell. Almost drove me nuts.
That is correct as long as somebody didn't put the coil on backwards and that is something that you should check. Make sure the negative side of the coil does go to the distributor. (This shouldn't be a problem unless someone put an aftermarket coil on) The guys on here are giving you some good advice. It shows they have had some experience dealing with these types of problems. Also the point gap is very important. Don't overlook it. The best way to set them is with a dwell meter. If you don't have access to one you can use a feeler gauge. Don't use a dime. (That was for Model A's) I believe the proper gap for that engine was 0.017. You can possibly do a search on FTE and find out for sure.
Okay so, I have some new info to bring to the table. Just remember I'm learning and I really don't know that much about ignition systems and I haven't had this truck for a long time so please don't crucify me for my dumb assness. I got to looking for the points on my truck to close them manually like fmc suggested and realized it doesn't have any and I also have a little black box mounted over on the driver side fender. This is and electronic ignition setup right!?
A jumper from the battery to the coil still has no effect (don't know if this has anything to do with it being electronic). I cleaned and checked the grounds that I could find (neg post to engine and starter to starter solenoid). I also hooked my multi-meter up (one probe to neg battery post one probe to + side of coil) and I get around 12v with the key on "run" and around 8-9v while the engine is cranking. Could that little black box be the problem? I think that is an ignition control module right?
Well, that'll change things a bit. Stock 74 could be a Duraspark I. Module is aluminum colore unless someone has painted it. How many plugs on it, and what color wires?
After some research and phone calls the distributor has been upgraded to a DSII from what I got out of it. Yes, it was aluminum but has been painted over. Two plugs on it.
The wires are old and some have paint on them but from what I can tell they are as follows.
On plug has four contacts
wires coming from harness into plug:
green-light blue stripe
orange-light orange strip
light blue
red-whites stripe
and another light blue wire with a little can thing attached to it
from plug to module:
red
white
purple
orange
The other has two contacts but the plug looks like it would accept three.
blue
lime green
red-white stripe
It certainly sounds like you have a Dura-Spark II system. I dont understand the colors though. On the normal Dura-Spark the plug with the two connections is for the voltage from the ignition switch. One puts twelve volts on the module in the start position. The other one puts twelve volts on the module in the run position. There might not be the twelve volts in the run position and that could definitely be the problem. You need to turn the ignition switch on in the run position and see if there is voltage there. If not then you have found your problem.
I figured something was up. Yes, you have electronic ignition.
I can't make out from your description what you actually have. Can you post photos of the box and the connectors coming from it?
Most likely you either don't have power to the box in RUN or the box itself is bad. I can't tell from your description where to look for power, especially since you've indicated that things have been moved around, and some wires have paint on them. That's why some good, clear pictures are necessary.
Where are you saying I should check for voltage. Unplug that connector and see if I am getting 12v on one of those contacts in the start position?
Also, it's like I said, those colors may not even be correct. That's just the best I could make out from the years of paint, heat, discoloration, etc of those wires.
You need to make sure you have power in the RUN position. You know you have power in the start position, because you state thats the only time the truck will run. Is the starter just grinding away on the flexplate/flywheel while you are testing it? If so, you need to stop, and get this figured out, before you need to pull the transmission and fix more problems. Need to try to take your time and read what these guys are telling you, they are spot on with what is wrong with it. Good luck.
Agree with 77393, trying to keep the engine running for 6 to 7 seconds with the starter engaging is going to kill your starter and/or ring gear.
The connector with 4 wires is for the distributor and coil. Two wires are the distributor trigger, one is the coil primary, and the last one is GROUND. Did you say that the harness-side of the second connector has three wires? I only see two in the picture, but maybe it's just the angle.
If the truck-side has three but the module has two on that second connector, then you may have the wrong module. Did the truck ever run in the first place? If they both have two, then next we can check for power.
