the dealer will tell you that you should have a trans service every 30k, for some reason we are still using the basic maintance times from 15 years ago.
So for cheezit or others knowledgeable about fuel and water.
If you we're to add diesel to your truck and it had water in it, how soon could you drain some fuel and see the water in there?
So would it be good practice while traveling to fill up and then drain some out to see what it looks like? Would that work?
I ask because I'm about to put 4,000 miles on it or so next month moving down south. I'll be filling up very regularly due to pulling trailers both ways.
My guide the truck came with says 60K. The second printing on Ford's website says 30K (Except Torqshift).
Thanks for your input.
If it were an airplane, you would drain a sample at evey fill up. Cause water in fuel can kill you. In my truck, when going coast to coast i just fill n go. If i get a water in fuel messgage (never have) id stop and drain lots of fuel. That being said i buy diesel at major brands that sell lots of fuel.
Yeah I try to as well but lately reading some of the threads it can make you a little paranoid.
My dad just came back from FL and they went to Virginia first and stopped at a racetrack stop and filled up with diesel. It took 20 min before they could get it to idle smoothly it had so much water in it. His is a 6.0
He thought being a large truck stop with lots of semi's filling up he'd be safe. But he had a large quantity of water in his fuel.
Just got me to thinking of ways to be preventative if I could draw a small sample off with each fill up.
It would be a pain but worth it if I could catch something early.
Based on claims of HFPF failures, the WIF light never came on for many. Service manual says "drain monthly or at oil changes." I drain mine monthly and get about 6-8 tiny droplets of water in about 10-12 oz of diesel. I keep the "evidence" in sealed mason jars in the garage, dated. Just for a little extra documentation.
I've tried keeping a powerade bottle in the truck and put 10-15 oz of diesel in it first and seeing if I get any debris or water before I fill up the truck, but I wasn't ever seeing anything in that small amount of fuel, I gave up on that route.
I dont see how thats evidence as i could put diesel in jars, add dates and some water. No way to know when or where its really from
Well, it's the same as those that maintain their own trucks and keep receipts as documentation that they changed their oil and fuel filters. I can think of at least a half a dozen ways to manipulate that methodology and not actually change my oil/filters as my receipts allegedly document.
I wouldnt say its the same. Receipts with dates and times have a great deal more trace-ability. Paired with a detailed log of some sort, i would venture to say is fairly substantial. More so than random jars with samples. I do see your point though. What about oil analysis samples on record by a reputable organization? Or how bout video documentation to include VIN and registration. LOL
That might be in the near future if Ford keeps denying claims.
I still think FWS samples sealed and dated is one up on just saying you drained it monthly.
Get Geico MBI and you will be worry free.
Also, what if i fill up a bunch of various jars with diesel when i get fuel, then label them as different dates throughout a year or so....and seal them...and use different colored pens. Do you think that will work? Just sayin....no way to verify right?
I change my oil at 6000 miles, and fuel filters at 12000 miles. I try to check water separator every month or so. I let the truck sit overnight before checking for water in the fuel.
ken
My first tranny flush will be next month, 103,000 miles by then.
I change the oil when the truck tells me too, usually around 7,500 miles.
I change fuel filters every other oil change, 15,000 miles or so.
I clean my air filter every 50,000 miles.
My first coolant flush will be at 103,000 miles but I did get new coolant at around 50,000 miles when I needed a new radiator.
My brakes squeak really loud now so I may throw some new pads on.
I rotate tires every oil change. (cross)
I drain the separator fairly often, always clean.
Part of the financial benefit of this engine is the longer service interval as compared to previous models, we save a decent amount of money if we follow the manual or maintenance minder in the computer.
I take pics of every sample of fuel. You can't change date on the pic. It's permanent info.
