cab question
Old Feb 3, 2012 | 09:41 AM
danmac82's Avatar
danmac82
7th Gear
cab question
hi there i have a 78 f100 i am restoring i have everything disconected from the cab accept the front mounts there is no holes to get at the bolts for the cab mounts im not sure if someone has put pans in the truck before i had it and covered the holes or if there was another way to get at them or if i am i do not want to cut holes in the floors as i dont know the exzact spot where i should cut and the floors are not in that bad of shape thanks for any help
Old Feb 3, 2012 | 10:00 AM
spikinfool05's Avatar
spikinfool05
should be a little access panel in the fenders look towards the back and youll see the cab mount itself. shaped like a football. its held on with a screw. take the screw out and it should remove. and the bolts right there.
Old Feb 3, 2012 | 10:25 AM
danmac82's Avatar
danmac82
7th Gear
thank you ill check it later on td and let ya know how i made out
Old Feb 3, 2012 | 02:58 PM
hickory1991's Avatar
hickory1991
Open hood. Cab mount acess panel will be located on bottom of firewall below your master cylinder. Look for tear drop plate that's held on with screws. Good luck.
Old Feb 3, 2012 | 03:22 PM
danmac82's Avatar
danmac82
7th Gear
found er thanks alot guys any more problems ill be sure to post
Old Feb 3, 2012 | 05:08 PM
spikinfool05
good deal.
ksmith203
20
Sep 5, 2008 11:16 PM
53pickemuptruck
Mar 12, 2007 10:37 AM
Rediranch_too
Nov 8, 2004 02:24 PM
1bad390
Mar 10, 2003 09:16 AM
