The "Death Wobble"
That said, if you have balance issues or the possible but very rare actual out-of-round tire problems, and replacing the tires or repairing the balance issue seems to have prevented any further occurrence of a death wobble, you're probably fine for a long time. Even new and perfectly in-spec parts can't always rein in a perfect storm of balance problems and road obstacles coming together in the right way at the right time.
Four hours in on I 287 in NY it hit so bad around 65 mph that you would swear the wheels were falling off. Hard braking and slowing to about 30 mph and it would stop. This persisted. Under 50 mph it wouldn't do it. The shake is violent and unsafe, Ford should be ashamed for always burying their head in the sand.
I'm a fanatic with maintenance so I knew everything was tight as I checked it myself. My tires are worn but not worn out. I checked front tire pressure as that's Fords blame to everything, it had rose from 75 psi (cold) to 80 psi (35* day). I dropped it to 75 psi. I have Airlift air bags and I began to drop those from 75 psi, now @ 40 psi riding partially on the helpers. Rear tires are @ 65 psi. I actually stopped once and removed the new stabilizer to make sure it wasn't defective (when you have a F350 you always carry a complete set of tools), it was fine.
By the end of the day after my adjustments, heading south (I 88 to I 81 Rough as *&%$, as long as I kept it above 70 mph (yeah scary) when i hit a bad crack or bridge seam it would start to shake but come out of it. DAY #2, no violent shakes, running @ 70-80 mph.
It feels to me like it starts with a wheel hop (vertical, shocks), then becomes a shake (worn parts). Terminology may be wrong, feels to that the control rod (one w/ the stabilizer on it) from the pitman arm (steering boxend ) to the steering linkage has very loose joints. I can easily roll it up and down.
I too have the extended warranty (learned from my 6.4!). Thinking my plan of attack will be new shocks, if I don't do them Ford will and charge me double. Then if the problem still exist bring it to a dealer. At least I can do the shocks on the road and not wait for a truck tech @ a dealership.
Starting to think....Dodge (or RAM for that matter) isn't a 4 letter word!
BTW, I've owned a LOT of trucks, My 88 GMC 3500 4x4 dually flatbed and 1983 Jeep j20 both had this issue, both leaf spring solid axle trucks, steering stabilizer was the cure.
Need to check for worn parts and get an alignment and set the caster to 3-5* positive. Steering stabilizer will only mask the issue.
Generally speaking, the service departments are bad to say the least. Most of the actual repairs have been made from researching the forums (usually when broken down in a parking lot, i.e. injector clamp failures 3 times before they replaced all of them) and "telling" them what to look for and where to find it. I think other here will understand the frustration.
1) The basics: Lateral reciprocal and uncontrolled movement of the front wheels as a result of uneven road input (pothole, railroad tracks, bridge expansion strips etc.
2) Steering stabilizer(s): I run 1 and only 1 because you don't need more than 1. I have seen guys add as many as 4. SS will NOT cure DW, what it does is to absorb the very small lateral movements, the more SS you have the more they absorb, sadly you are only delaying the inevitable sooner or later you steering and axle locating components will wear to the point that even 20 SS will not absorb the lateral movement and DW arrives full force.
3) Cause(s): ANY component(s) singularly or in concert can and will cause DW. Especially the Track bar which locates the axles under the vehicle, so will worn shocks, worn steering components especially those in the steering tie rod, ball joints...if it hangs underneath the front frame then its on the list, simple as that.
4) Fix (s): There is no long term fix due to continued component wear. 1) At the first sign of DW MY first step is to replace the SS and 2) either the axle locating Track bar itself or the bushings if they are the press in and 3) inspect all other bushings. NOTE: Misalignment and or tire pressure can be a cause. As part of your regular inspections you should always insure your vehicle is aligned to specs ( unless you have a modified vehicle such as larger tires etc, then your specs must be adjusted to compensate ) and you run the spec tire pressure and are balanced!!!!!
If after doing that you still have DW then I go straight to the ball joints and inspect for worn front shocks.
When I had my shop DW was a common problem especially on Jeep TJ's (97-'06). I never once failed to fix the problem on a customers vehicle.
* Got front wheels, you too can expect DW sooner or later TO INCLUDE DW on your MOTORCYCLE. Want scary, be on your Harley at about 75 mph and get DW, now THAT is SCARY!!!!!!! It does NOT have to be a solid axle vehicle to get DW! Shopping carts get it, so do Corvettes and just about any car out there. But its the bane of solid axle vehicles.
You're 100% correct. I had a 1981 Suzuki GS 550T that experienced DW, not fun. New Metzlers cured it.
I'm thinking I'll change shocks first, road test, than bring to Ford to check for their opinion on worn parts as I have extended coverage (shocks wouldn't be covered so they will blame them first).
It's real interesting, if you dare to keep it above 75mph it won't happen. At 70 mph it tries to. After the first day, 1500 miles and 3 days @ 75-80 mph towing and no issue,
, but you can tell it's there as you pass from 60 mph to 70 mph just waiting to show its ugly face
This may be one area were a dealer/warrantee won't help you, but the issue is always solvable. You may have to take it to someplace that is willing to think and analyze, not just say everything is 'ok' (new parts, in spec)
If you don't want to buy aftermarket radius arms with added or adjustable caster, just modify your stocker arms. Not hard to do couple washers and a welder.
Good luck to those who suffer, be safe and enjoy your truck.
That is also why bicycles tend to be pretty darn stable, lots of positive caster. It takes more effort to turn but once straightened out will hold that line pretty well.
You can have success with tire caster and tire pressure using OEM specs at +/- the next size up/down from the OEM tire.
As you go beyond that you get further from OEM specs.
OEM specs for '03 Rubicon TJ = +7 degrees +/- 1 degree
37 in: 5 degrees [I run 37 BFG KM2s, 36.8 in diameter tire, and 18 lbs of pressure]
35 in: 5.5 degrees
33 in: 6 degrees
