Yet another HPFP question
Old Feb 3, 2012 | 06:31 AM
ruschejj's Avatar
ruschejj
Isn't this topic the result of 2 trucks? One truck? I don't remember. We are all wound up over 1or 2 failures.
It's interesting and unfortunate for the ones that had it happen but really, we have found less than five failures?
I'm trying to learn from it and also enjoying the information because it is interesting but I am not worried. If it happens to me I will at least know what's going on.
Old Feb 3, 2012 | 07:32 AM
aaronbrace's Avatar
aaronbrace
That is a very valid point but we also need to remember that this is 2-3 trucks out of a relatively small sample size. A very very very small percentage of 6.7L owners are members of this forum.
---Aaron
Old Feb 3, 2012 | 07:52 AM
jack_pine's Avatar
jack_pine
---Aaron
That is true. I do think the number of trucks represented is much larger that the number of members. I, For one, know 14 people with these trucks and would report any issues they had.
I know is is still only a percentage of the trucks on the road.................
powerstroke72's Avatar
powerstroke72
Originally Posted by dbc001
Powerstroke72 .... while I get the obvious about keeping the VW stuff out of here I have to say the information presented by NinerBikes has been very valuable. There are more similarities than not when you dial in the concepts, pump manufacturer, longer experience trail, and VW responses to the issue. Their analysis of the roller cam and the defect in design and the materials used was great. This could lend a ton of credibility to our cause if in fact there is a cause. I for one am willing to see through the VW haze to gleen as much info as possible ...... even with the fact I could pull 20 VWs down the road and they couldn't pull one SD
That's the nice thing about opinions. We've all got them and.....well you know the rest.
You don't have to subscribe to a 'sky is falling' theory to need to be legitimately worried.
True but there's no need to try to stir up knee-jerk type hysteria over mass failures that have yet to be proven. Although this may be a very small sample of the 6.7 owners out there, no one has been able to provide any statistics or figures showing massive failure rates. Even one of our member techs here has said he doesn't know of any mass failures.
Originally Posted by HeckRat
The issue is not what is at present, very isolated cases of HPFP failure.
The nature of the failure (catastrophic, no warning, no CEL, no Wrench, no noise, etc.) and the consequential damage (whole fuel system repair) makes it baaaaad.
What made it an issue is the ease / readiness with which Ford denied warranty coverage and the onus on the owner to prove (however that can be done) that it is not Water or contaminated fuel that caused the problem.
Had Ford ate the bill and figured out the problem and then retrofitted a fit, it would be a non issue.
If you presently own the 6.7, there is no reason to get worked up, no reason to do anything different except:
- Watch for Water in Fuel light
If it goes on... stop immediately and purge water.
- Change fuel filters on a tighter schedule and SAVE them
- Occasionally, cut open one of the above ones looking for metal shavings.
Always be on the lookout for odd behavior / noises etc.
Have a 6.7 in your 2005 Econoline do you? Oh that's right.......you claim to have a 2013 F-150.
Old Feb 3, 2012 | 08:27 AM
consolidated's Avatar
consolidated
So, I think a better question to ask over 150K miles is not whether the pump will wear out because it has been eating a steady diet of 520SCAR ULSD but : What are my chances of getting a tank of fuel with some emulsified water in it or fuel that never had the lubricity additive put in by the refiner/blender over 150K miles? Unfortunately over 150K miles I think there is a decent chance that will happen...1:20? 1:40? Not good odds when you are talking about a $12k bill.
---Aaron
This sums up the dilemma for owners.
Old Feb 3, 2012 | 08:51 AM
UGA33's Avatar
UGA33
Talked to my buddy about these two issues the other day being that he is not a member on this forum. He said while it sucked Ford wouldn't go to bat for them, the majority of the fault is on the techs. In the two years these motors have been out, he has done to date two motors due to dropped valves (4 and 550) trucks and one turbo. He said at the dealership where there are three diesel techs, the topic of job security has come up between them with the 6.7s current track record at this point. Said they may be going back to the 7.3 days where all you did was change fluids and brake jobs. Moral of the story? Enjoy your trucks guys. They have been off to a great start so far!
Old Feb 3, 2012 | 09:17 AM
FTE Herman's Avatar
FTE Herman
While I appreciate the commentary, can I get your opinions on my original point?
Have you ever drained your oil on a motor (or trans) that had a magnetic plug or magnet in the pan and found metal shavings? (I have.) Did you freak out because you found metal shavings? (I didn't.) Now if I take my reasoning for my reation to this, it is based on the fact that the magnet is there to keep the silver sparklies out of the moving (read delicate/expensive) parts of the machine.
So am I wrong in assuming that just through the process of normal wear, that we are all looking at a 10K repair bill at some point in our future?
If I were granted a wish for today (it's only money and a truck, it's not like my health, just so you know I have things in perspective) it would be that Ford engineering explain to us why the could have designed a system with such an apparent flaw or why our perception is not a flaw at all.
Old Feb 3, 2012 | 10:55 AM
UGA33's Avatar
UGA33
Completely understand your feelings. I just bought a 6.4 last week and on its first oil change i did Saturday, it's already making oil as of yesterday. Not nearly your problem, but I do plan to own this truck outside of warranty and wonder with all the diesel in the oil, how bad have my bearings in everything been washed down. My answer to my problem? I have a diesel tech that I know will make anything right that's under warranty. I wish it was like that for everyone.
Old Feb 3, 2012 | 12:03 PM
rickatic's Avatar
rickatic
Herman
Not only do I understand your question, I am baffled by the apparent lack of concern by some here that have to know better. Ford has violated one of the most basic principles of engineering and design. They surrendered the engineering margin. As an engineer, you see this clearly...for some reason, others choose to turn a blind eye.
Interesting thread...in less than one page I have been slammed three or four times for posting factual information...lets see...
I have been called a fear monger and told to STFU. First, I have only told the facts. If you have facts that refute mine, post them. Here are the facts:
ULS diesel fuel in the US has a minimum requirement of 520 micron scar rating for lubricity. Where are the opposing facts to this fact?
Bosch has published information that clearly says that their HPFP's require 460 micron scar rating for lubricity to operate successfully for the long term. Again, opposing facts please...
Bosch has also published information that clearly says that 500 micron scar rating fuel considerably lowers the lifespan of the pump...as much as 80% reduction in lifespan is mentioned. Please provide facts to the contrary....
Using Bosch's own publishing's, it is a certainty that Ford has decided to install a HPFP that when exposed to industry standard fuel quality in the US, is below the minimum standards specified by the pumps manufacturer. If there are facts out there to refute this, please provide them...
The Bosch CP4.2 HPFP is only one model of pump on the CP4.xx series. The pumps are identical across the series in both design and operation. It matters not whether the CP4.xx pump is a single piston pump found on a VW TDI or a two piston design as Found on the Ford 6.7. Except for housing mount alterations and the single versus twin cylinder cam, the internals of the CP4.xx series pumps are identical. This makes the history of other brands failures relevant to the conversation. They have had a much longer period of time in the field than the Ford 6.7. Claiming that the facts in other brands arena have no relevance is ignoring many sound engineering principles. Facts that show difference in internal operating parts between the various CP4.xx pumps are welcome.
The engineering facts have been presented. Hopefully, the gamble Ford took with this HPFP will not affect a large number of owners. The small sample of failures to date, much larger than some here want to admit, is not relevant to the engineering discussion. Only time will tell if the engineers are smarter than the bean counters.
How is the presentation of the above facts considered bovine excrement? How is it considered "sky is falling" mentality? Where has it been written that these failures are widespread? Why is pointing out the truth that Ford is avoiding warranty coverage whenever possible on HPFP repairs considered a bad thing? If you disagree with the assertion that none of the owners of a 6.7 Ford diesel are immune to this unfortunate failure and the subsequent warranty denial, please tell us how you can be so sure?
Broken record...funny...I provide facts and I am a broken record. The argument from the other side has no refuting presentation but their constant pounding of my reputation is less a broken record.
For the record again, the sky is not falling...yet. It may never fall...but the soundest of engineering principles tell us that operating "in the margin" is never a good thing. Ford has put owners in the position that they have to worry about an engineering decision that could have been avoided. If this does not bother some here...I suggest they ignore the HPFP threads. If you do not like the facts I post...refute me or ignore me...I won't mind...but if you think I am going to STFU...you are dreaming. The truth about the decisions by Ford that led to these discussions needs to be told...and I will help tell it...
Herman,
Thanks for the thread...and enjoy the new truck...I drive mine every day and smile
Peace
Old Feb 3, 2012 | 12:33 PM
rickatic's Avatar
rickatic
All of the above are reasonable facts --- but the one conjecture --- that Ford/Bosch knowingly put in an underspec pump for the lubricity normal in USA, bothers me.
There is something at work here we do not understand ---
Nor did Bosch or Ford.
I am wondering aloud here --- whether it is the behavior of supercritical fluids and something in North American diesel becoming reactive and damaging the Diamond like carbon coating.
Not a simple problem --- hence the need to carefully examine pumps with early signs of problem --- and not wait for the pumps to die completely first.
I must respectfully disagree on the conjecture part...The ULS Diesel Fuel specifications have been around longer than the CP4.xx series pumps. Bosch's own published documentation clearly shows that in 2009, they were concerned with the lifespan of their HPFP's when exposed to lubricity levels above 460 scar. I find it difficult to believe that Ford did not have any conversations with Bosch over the specification shortfall let alone not read the publishing's...otherwise, we are in agreement
I sent you a PM with my email address
Regards
Old Feb 3, 2012 | 12:52 PM
bookem15's Avatar
bookem15
Something to think about......
Let's say in 4-5 years some of us want to trade in our 6.7's and we take it to the dealer and try to trade it in on a new one and they tell us that it is not worth that much because "you have one with a bad fuel pump and we are going to have to change the fuel system out" therefore your trade value will reflect that. I for one saved alot of money and traded in a paid off truck to get this truck and to now find out that Ford built it with substandard parts pisses me off. If I would have known about this issue before I bought it I would be rolling around in a 2007 SD 6.0 and still had my money I saved. This is the one thing I have not heard is what is this HPFP issue going to do later to the trade in or resale value. All one has to do is look at the value of the 2003-2005 6.0's they suck and after paying 60,000 dollars for a truck that pisses me off.
I realize that there are a small number of failures but what is scary is the few people that are reporting the metal in their fuel filters. Time will tell whether we have a big issue or just premature worry for nothing.
Just my .02
Tom
Old Feb 3, 2012 | 01:04 PM
bookem15's Avatar
bookem15
I agree we should give them time but the fact remains it effected 3 years worth of trucks values and durability before they fixed it. They have it fixed and you still can not get the same money for those years of trucks it still effects the value. How much in value we are going to lose remains to be seen and for how many model years is it going to last?
Old Feb 3, 2012 | 01:07 PM
  #28
B&LLandscaping's Avatar
B&LLandscaping
Originally Posted by FTE Herman
As some of you may know, I’m new to the diesel family after many years of wanting. One of the reasons I’ve desired a diesel for so long is durability and longevity. This impression comes from many friends of yesteryear (80’s and 90’s) who used diesel one tons in their business, hauling equipment from place to place in the state of Florida. I was always impressed as to how long and how many miles these vehicles served before requiring ‘major’ maintenance and on this topic, what I remember them all exclaiming “it’s time to get the injector pump rebuilt”.
With this in mind combined with our recent negative experiences regarding our HPFP’s apparent premature failure, I have to ask: are we all destined to a massive (~$10K) ‘maintenance’ bill in our distant (~150K miles) future?
I only ask because this seems to be the only logical conclusion: as the HPFP wears (even normally) it’s going to release metal into the fuel system and when it’s time is up (and perhaps before) we are not only looking at a fuel pump but also the remainder of the fuel system, which we know is about $10K in price.
Tell me it isn’t so, because if it is, I have a really nice, low miles 6.7 for sale.
Trust me, I’m not bashing, but if I had known I’d be in for this, I never would have bought the truck in the first place as I could easily swing a brand new gasser at 150K for less than the cost of what I assume is ‘normal maintenance’.
Sell the truck then before you give yourself an ulcer worrying about it.
I'm sure someone will be glad to take it off your hands...
Old Feb 3, 2012 | 01:24 PM
  #29
bookem15's Avatar
bookem15
Originally Posted by rickatic
It is hardly an assumption when Bosch publishes it's concerns for all the world to see...I did not write that paper...the leading authorities on HPFP's and diesel fuel did... if they did address the issue...it appears that their fix may also be suspect...keep whistling
I intend to keep writing...
Peace
I would like to see what their fix was assuming they came up with something. I do not want to bash on anyone but the fact remains something is just not right.
Old Feb 3, 2012 | 01:30 PM
  #30
dbc001's Avatar
dbc001
It is interesting where we are on this one. I am very sure Ford just didn't ***** nilly a pump from Bosch without fore knowledge of specifications, use, deployment and so on. Most importantly I'm sure they didnt select it without an actuary of costs on risks. I also fail to beleive that Bosch just sat there and did a fist pump on selling 500,000 CP4.2's, (and 50,000 plus for failures and ongoing revenue stream) to Ford without providing clarity on the use, application, and life expectancy.
Truth is we will never know the symantecs behind the decision to use this pump from this manufacturer. To think otherwise would be totally unfounded speculation for which there would never be an answer unless there was a FordGate/BoschGate.
I'm starting to feel that hammer coming again ....... the wild and crazy guy is swinging it now ....... going once....... going twice ......... (Tom: enter comment here)
