Really stupid question for you
Get a piece of chalk (I use my grandaughter's sidewalk chalk) and draw a wide line across the tire tread. Then drive the truck a few feet and see how much of the chalk came off. Adjust your pressure up or down to get as much of the line off as possible.
The quicker way is visually. Let air out until the bulk of the tread looks like it's sitting flat. Then drive it and see if it's too squirrelly.
my truck is a reg cab with a 5.4.
i run 55 in the back and 65 in the front.
any more in the back and the outer edges are un-touched.
my experience is that you can actually go a lot higher in the front due to the turning geometry of the twin i-beam suspension i have.
but i run 65 to keep the ride quality.
my tires are BFG Rugged Trail TA in 235-85-16
my last tires were cheap nexen tires that came with the truck and i could go all the way up to 80 and get even tread wear, i guess the tread was much stiffer or something.
in general, i have noticed that BFG tires seem to "Bulge" more than other tires but the quality of the tires are (IMO) un matched for the price.
Do not EVER run more PSI in a tire than it is rated for the sidewall, no matter what the sticker says. That sticker was for OEM equipment only, and unless replacement parts are 100% identical to the OEM tires, then the sticker becomes worthless. If you put D-rated tires on a SD, you cannot fill them up to what the door tag says, because 1) the tires do not meet the specs of the OEM equipment for pressure, and 2) it would exceed the safe maximum PSI of the tire per the manufacturer.
There is absolutely no way around this. The door sticker is only for original equipment or 100% identical conforming replacements.
There is absolutely no way around this. The door sticker is only for original equipment or 100% conforming replacements.
Superduty trucks come with load range E tires, that is the tire the truck was designed for.
How To Check Tire Pressure
How to Check Tire Pressure
Tires have been known to lose up to 1psi (pounds per square inch) every month, so check all tires, including your spare, once a month (or before a long trip). It’s easy. Here’s how:
- Purchase a trusted pressure gauge.
- Check your tires “cold” – before you’ve driven or at least three hours after you’ve driven.
- Insert pressure gauge into the valve stem on your tire. (The gauge will “pop” out and show a measured number. When you hear a “pssst” sound, that’s air escaping the tire. The escaping air shouldn’t affect pressure substantially, unless you hold down the air pressure gauge too long.)
- Compare the measured psi to the psi found on the sticker inside the driver’s door of your vehicle or in owner’s manual. DO NOT compare to the psi on your tire’s sidewall.
- If your psi is above the number, let air out until it matches. If below, add air (or have a Michelin retailer help you) until it reaches the proper number
But since you only seem to be able to believe stuff from Michelin's website, here:
Congrats on the new truck! Bet you never thought there would be such a spirited debate over what you considered a stupid question huh? But in answer to your question, I run mine at what the sticker says. But your milage my vary. What jmiley can't seem to get through his head is that all trucks aren't kept stock. I'm unoriginal so mine is running the stock tire size and specs, it sounds like yours is as well. It also rides like a lumber wagon unloaded, it's better if the pressure is reduced but the truck isn't my daily driver so I keep them full b/c I'm usually hauling if I'm in the truck. I wouldn't see a problem reducing the pressure to 55-60 to help the ride a bit. I couldn't tell a difference in handling on mine.
Wow. You always do what everyone tells you? Probably never torn off a matress tag either. But seriously, you think Smotrs should run 65psi even though his tires say 50psi max?? That's just stupid and dangerous, thankfully he's smarter than that. His tires aren't what's spec'd from Ford, many aren't. It's dangerous to make blanket statements like yours.
Yikes. Clearly if the tires are only rated to 50 psi you wouldnt put 80 psi in them no matter what ANYONE would say. Ford also claims a certain gwvr, but if you decide to put some small tires with say a 1500# load rating you obviously wouldn't think your gvwr would be the same?
Right?
Talked with a buddy of mine, works for local tire company., he told me not to go over 60psi for running empty, 60psi was his suggestion, he knows me and my "load". I trust him completely. My "load" will be a 3000# trailer with about 300# of tounge weight.
Was running this load with a F150 w/4.6 and was working it to death.
Geuss I went from eitting by to OVERKILL!
Really like the new truck, F250's are soo much more than the old F150!
Dan B.
Central Ks.
